a/c questions.
Old Jul 19, 2002 | 03:21 PM
dan's Avatar
dan
Get the fuck off my lawn
Default a/c questions.
ok so today i got a few a/c lines replaced they were leaking and a new condensor canister and charged up. the guy tells me i have a slight leak in the evaporator core but it should be fine.
so i went home and it blows cold oh yes its so nice then my compressor starts to kick on and off. compressors wont kick on if its losing pressure so it seems the leak is getting worse than he thought.
so after $500+ in parts and labor, the condensor core is a radiator like thing that my dad says might need special sealant and oil or something in there (didnt understand what he told me) and i find out its under the fucking dash.
so i am asking to see if swapping out a core is do-able DIY. if not, i will at least be taking the dash off myself to get to it (pretty sure i have toremove the dash unless its accessible under teh glove box or something). and that might save some labor since they'll just have to swap the cores and ill do th rest, saving me labor money.
if i do forego this procedure, i will need to know details on pulling the dash (im sure i can do it) but i will specifically need instructions on properly disconnecting and reconnecting the passenger side air bag. i do not want to make it go bad or blow up on me when i reconnect it.
thanx
dan
Old Jul 19, 2002 | 09:00 PM
dan's Avatar
dan
thanx. i dunno if i would be replacing just some of it or the whole thing but would u know if there is any needed sealant/seals/oiling etc at all.
i drove around tonight and it stays on so im thinking that since it was just put together it needed to cut on and off a for a while to get back in its usual or something. but it hasnt been cutting on and off at all. i will drive it tomorrow in the day again since perhaps the heat might be doing it cuz tonight it was cooler out dunno if that would have anything to do with it.
thanx though. for now im fine which is a relief.
Old Jul 19, 2002 | 11:57 PM
Matt Vassallo's Avatar
lifelong learner
are you R134A or R12?
I can grab you some stop leak shit from advance. maybe it will work. only if youre r134a
rest in peace tim.
Old Jul 20, 2002 | 09:07 AM
dan's Avatar
dan
134a but its not leaking at this moment.
Old Jul 24, 2002 | 11:41 AM
dan's Avatar
dan
just wanted to close this "case" so to speak
yes i know u have to replace condensor/drier canister. they did so. they replaced 2 lines they said were leaking tho i can only find one that looks new. the L pressure line that has the big bulge that connects to the compressor.
the a/c works perfectly so am in no troubles at this moment.
thank you jay for the info.
oh and my new drier is brand new obviously it came shiny/polished so if u get the new one for garrett's you might not have to do it. (but no it doesnt compare to stage 2 its only like stage 1 shine)
Old Jul 26, 2002 | 09:21 PM
LogicalRetard's Avatar
Cafe Racer Extraordinaire
I want to hook mine back up, but's it's R12....anybody get some cheap R12?
Old Jul 27, 2002 | 05:34 AM
lifelong learner
fill it with propane
rest in peace tim.
Old Jul 27, 2002 | 02:26 PM
dan's Avatar
dan
ah shit. leaks again, time for new evap core time!
