ecu upgrade?
Old Jul 12, 2002 | 08:54 AM
obituary's Avatar
TR OG
Default ecu upgrade?
what is a good and cheep ecu for the sr20 det? (JWT) or piggy back type A'pexi.........im confused....or any others?
Old Jul 12, 2002 | 09:34 PM
LogicalRetard's Avatar
Cafe Racer Extraordinaire
JWT....they can program what ever you want.....just think....that's what they specialize in.....Nissan's....thery have a lot of experience with DE-T's. Give 'em a call.
Old Jul 13, 2002 | 06:25 AM
TropikalSX's Avatar
S14 PILOT
Why use a non-upgradable ECU re-tune??? Once they zap it for all that $$$ you have to send it back in to get it tuned again... Instead of that get this:
Greddy E-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system, without having to change the entire factory ECU system to an expensive "stand-alone" unit. The E-Manage system is a universal "piggy-back" type unit, which taps into most factory ECU wiring and it still utilizes the existing sensors (YES, it is avail for the SR20DET). Basic functions will allow the user to slightly alter factory injector duty-cycle (ア 20% at 5 preset RPM points), by intercepting and altering airflow or MAP sensor signals. For VTEC cars, you can adjust the VTEC shift point.
Additional features that are built into the system, but are only accessible though the use of "E-Manage Support Tool" software are a 16x16 Airflow Adjustment Map, Larger Main Injector correction adjustment, Upgrade Air Flow Meter adjustment (AKA, Z32 AFM), Boost Limiter Cut, Anti-engine Stall, VTEC-fuel adjustment, Real-time Map Trace, Real-time Display, Real-time Communication, and basic Data-logging.
Any Pentium based Windows laptop will be able to use the software. It will have the ability to control an additional 16x16 Injector duty cycle Map and the Controls for adding up to 2 Additional Sub-injectors. If the "Optional Ignition Harness" and the software is used the unit has the ability to control a 16x16 Ignition Timing Map. All of the above Maps can also be Map-traced in Real-time as well. If the factory range of Map or Airflow meter is surpassed, you can incorporate the "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment.
This little piggy back can be yours for: $345.95 You can change the settings when you MOD your engine. SO, for basicly the same price as a JWT re-tune or less why not purchase this? Unless you are not planning any upgrades, or are lazy..
Old Jul 13, 2002 | 03:57 PM
obituary's Avatar
TR OG
i plan on a bigger t03 turbo,front mount I/C, bigger fuel injecters,and a 300zx fuel pump in the future..............any one know how much $ to rebuild a Air reserch T3turbo..........?will the TT300zx injecters fit the DET?
Old Jul 14, 2002 | 08:26 AM
BumpinPSI's Avatar
Eye Heart Nissan
You arent running your SR20DET on the stock fuel pump are you?
Is this Sentra or 240SX related?
Tampa Bay Lightning - 2004 Stanley Cup Champions
Old Jul 14, 2002 | 08:42 AM
obituary's Avatar
TR OG
i plan on runnin stock for a while ............what the stock fuel pump wont handle it???? its worth a try ...........$$$$$$cash flow is da problem!!and i want to get the bitch on the road....
Old Jul 14, 2002 | 08:44 AM
obituary's Avatar
TR OG
240sx
Old Jul 14, 2002 | 08:45 AM
obituary's Avatar
TR OG
240sx
