Figure this out!!!
Replaced the distributor because cyl. 2 & 3 were not receiving the same spark as 1 & 4. Plus when I removed the distributor it looked like shit. Set the car to TDC, because I pulled the distributor. Replaced the plugs and wires, because they looked like shit and probably had 10000000 miles on them. Replaced the fuel pump, because when we pulled it from the tank it sounded like a dying cordless power tool and the new pump was free. Wired the fuel pump to acc to eliminate power issues and it took like 5 min. Replaced the fuel filter, because it was 10 bucks and I would have to spend 5 bucks just to try the car without using a filter. Sooooo yeah considering I am broke and have no idea what is wrong I will replace old parts when they are either free or cost less than 10 bucks and may fix it. I think it is a fuel problem, because I have air and spark... leads me to believe I need fuel. Plus I can squeeze the feed line together with my fingers when its primed.
Um...... why are you even posting???? This is completely useless info brah... and I didn't "trash" my quarter panels.?.? I did however pull them so my csts' didn't look like everyone else. Also.... please tell me how this is relative to me having typical Ka gremlins?????
me and my thoughts of reading the post would say...
if u can pinch the like have u tryed a different FPR???
do you know for sure that the pump is putting out volume...
i have had a fuel pump sound brand new. but it didnt push but 1gph...
when u wired to ignition.
how did you do it?
are you sure ur timing is set right.
are you sure ur injectors are working???
have you tried a diff ecu if u have one to see if thats the problem?
how did you do it?
Originally Posted by Empire oh no. another ass hole 240...
sounds like an fpr to me....
live to love the RWD.
89 seafoam coupe w/ SR20 and more- FOR SALE<- click
FAX
______________________________
FAX
in my experience, working/good parts aren't free. I'd bet you replaced your crap fuel pump with another crap fuel pump.
Like everyone else has been sayin, you have to give more info. You have yet to say if this car was ever running. Does it start? How did it die? Did it run like shit for a while then finally give up or was it an all of the sudden thing?
How do you know you are getting spark?
How do you know the timing is right?
What does it do when you try to start it?
We can't see the car. We don't know anything about your car and its history. Hell, we don't even know if you know how to use a wrench.
Give good info, get good info.
Well If someone wants to come by and can get it running I am willing to pay $100 dollars. If you can't get it running I will buy you lunch and some beer. The car ran for a couple of weeks, but made ~100 hp it felt like. Then I switched my fuel rail and it ran even worse and made me think there was no spark. So I put my old fuel rail on and drove it home where it died. Just completely took a shit. I have no idea whats up. If someone thinks they can fix it you have lunch and beer and $100 bucks.
why dose a fuel rail effect the way your car runs??
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
