i hate cars
Old Apr 27, 2010 | 09:27 PM
jamesp65's Avatar
Default i hate cars
Alright so I thought it was my fuel pump messing my car up, got another one swapped it in and still runs like garbage. The only thing it did was add a gas smell. So now after checking a million things I'm at a loss.
Now onto the problem, it bogs down really hard at full throttle and low rpms. It feels super laggy to any throttle really and once in a while it just won't start without hitting some gas.
The last thing I can think of is fuel injectors....maybe? I guess I wouldn't post this if I knew.
Old Apr 27, 2010 | 09:28 PM
4wheeldriftS13's Avatar
February - Ride of the Month
if its a single cam, check fuel injector o-rings seriously.
RIP Tim Aldrich
Old Apr 27, 2010 | 09:33 PM
jamesp65's Avatar
Dual cam. The guy said he replaced one....I just remembered that haha. Anyways dual or sohc would the o rings do that?
Old Apr 28, 2010 | 04:15 AM
Zenkijavier93's Avatar
Check each fuel injector and timing. I had to replace 3 fuel injectors when I swaped motors
Old Apr 28, 2010 | 06:46 AM
Petitt's Avatar
The Riot Society
could be as simple as your distributor button/cap. mine acted similar when it need to be replaced
Old Apr 28, 2010 | 08:47 AM
Empire's Avatar
buildin' it
sounds like a dizzy problem to me.
make sure your coil is good.
then, might as well just replace the cap and rotor.
get new wires.
new spark plugs.
make sure the timing is right.
Might even have to replace the dizzy itself if the CAS has bad or if something really dumb, like the shaft is bent.
Old Apr 28, 2010 | 08:56 AM
jamesp65's Avatar
Was getting ready to do my dizzy next check. I'm just in a bit of a bad situation so id rather try to pinpoint things vs change everything.
Old Apr 28, 2010 | 11:11 AM
170k240's Avatar
Will Drift For Tires
replace all of your fuel injector o-rings.
Nissan North America - Canton
Old Apr 28, 2010 | 08:31 PM
1337240sx's Avatar
get the fsm and a volt meter and go CRAZY its what me and empire did when we ended up finding out it was my dizzy. cost me 200 bucks and motor ran fine till rodknock came.
Originally Posted by Empire oh no. another ass hole 240...
