S14 Issues Once Again!!!
Old Apr 2, 2010 | 12:29 AM
Scarface_613's Avatar
Default S14 Issues Once Again!!!
I am at a complete stand still at this point.
I have a 95' that i just swapped my motor into, The car is not getting any spark however it DOES have fuel. I have replaced the dizzy, rotor, cap, plugs, wires and have checked all the transistors and relays and fuses. All the motor does is crank over and nothing. I have even replaced my harness with a friends and it does the same exact thing.
I do not get why it is not getting any spark.
When it first cranked over it sputtered and ever since then NOTHING...PLEASE HELP
Old Apr 2, 2010 | 01:44 AM
MacGruber's Avatar
MaDe Of MoNeY
coil?.. did you check to see if you have spark at all? have you tried swapping ecu's? check your timing on the dizzy.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Apr 2, 2010 | 07:28 AM
ecu is good...timing is set...no spark!!!!
Old Apr 2, 2010 | 10:20 AM
MacGruber's Avatar
MaDe Of MoNeY
so its probably your coil or plug wires... you wont get any spark with a bad coil.
Old Apr 2, 2010 | 10:46 AM
Spark plug wires are good...how do I check the internal coil...it works in my other s14
Old Apr 2, 2010 | 02:47 PM
MacGruber's Avatar
MaDe Of MoNeY
scratch that my fault I had s13's on my mind with the external coil and if you already changed your dizzy then that wont be the problem.. your best bet would be start checking continuity on all your wires comming off your dizzy
Old Apr 2, 2010 | 05:05 PM
yea thats what i was planning on doing next...im just gonna take my engine harness from the running s14 and see if that helps
Old Apr 2, 2010 | 05:13 PM
MacGruber's Avatar
MaDe Of MoNeY
sounds liike a good plan.. post up what you find out..
Old Apr 2, 2010 | 07:58 PM
Empire's Avatar
buildin' it
yeah, sounds like a bad plug/connection to me seeing as how the dizzy worked on the other motor...
Old Apr 3, 2010 | 07:48 AM
yea thats the frustrating part, everything that i think is bad turns out being ok when i swap it out. Thats why i replaced the whole dash and body harness from a 5 speed shell thinking that it had a short somewhere(which it still might) and then you get so bummed out when you crank it over and your back to same thing. Ill update you guys when i get back from my mini camping trip and see what happens. I dont see what else it could be. Also thanks for all the replys and help.
