SR20DET Blacktop w/ Garrett GT2871r .64 turbo dyno charts
Old Apr 1, 2010 | 11:37 AM
supra33202's Avatar
Default SR20DET Blacktop w/ Garrett GT2871r .64 turbo dyno charts
Single 17.2PSI boost run:
Multiple runs:
My 1991 Nissan 240sx S13 with SR20DET got dyno and here is the mod list.
Engine:
1996 SR20DET Blacktop w/ Garrett GT2871r .64
Apexi 1.2mm head gasket
Arp studs
Tomei 256 cams
Brian crawler springs, retainers
Cp pistons, rods
Fuel:
Nissan oem 740cc injectors
Walbro 255 fuel pump
Sard fuel regulator w/ gauge
Splitfire Direct Ignition Coils
Breathing:
Z32 n62 MAF
Apexi power intake filter
Greddy intake piping
Greddy VSPL intercooler
HKS SSQV Bov
Greddy intake manifold
Fullrace exhaust manifold (bottom mount)
Garrett dump pipe
Megan test pipe
RSR Ex-mag
Drivetrain:
DSS aluminum driveshaft
Toda lightweight flywheel
Exedy 3 puck clutch
Electronics:
Blitz SBC id boost controller
Apexi PowerFC with commander
Questions:
1) Are my dyno curves look good?
2) If I set the boost controller 0 boost, it means stock boost right? Then, I should have 6-7 psi for stock internal wastgate for Garrett GT2871r turbo. Then why the chart show 0 psi (3rd pic of the "Multiple runs")?
3) How do I correct the 10 psi boost creep shown on the 3rd pic of the "Multiple runs"? Should I set the gain on the boost controller differently?
Thanks!
Old Apr 9, 2010 | 07:13 PM
weldedslidewayz's Avatar
those numbers seem to be about on par with the mods you have. I used to have a blacktop making 330ish at 17 psi but it was running way way way to rich. The curve looks pretty good, but I really don't know too much about dynoing. Also if your running the stock waste gate without a boost controller then you will run 6-7 psi.
Old Apr 9, 2010 | 10:22 PM
mewantkouki's Avatar
no
Your dyno curves are look good man!
Old Apr 10, 2010 | 05:52 AM
4wheeldriftS13's Avatar
February - Ride of the Month
^hahaha
nice setup/numbers.
RIP Tim Aldrich
