wierd spark issue
Old Mar 30, 2010 | 12:53 PM
1337240sx's Avatar
Default wierd spark issue
car ran fine last night(had empire over) for 10 minutes.
would be rev happy.
at the 10 minute mark cyl 4 losses spark.(like clockwork)
at the 11 minute mark cyl 3 losses spark and car dies.
waited 10 minutes.
car started perfect would idle (wouldnt really rev without a backfire or 2 thinking the o2 is bad...) but it would rev.
10 minutes on the clock losses cyl 4...
11 min cyl 3...
did it 4 times in a row.
today i tryed to start it at about 1shared_pm. started but couldnt get it to rev well atall.(had to floor it to get it to move 10 feet... and even at that i barly got it to move)
empire and i went threw the book and tested everything. nothing looks out of order atall.
Originally Posted by Empire oh no. another ass hole 240...
Old Mar 30, 2010 | 07:49 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
coil pack
Drifting:
most fun you can have
with your pants on.
Old Mar 31, 2010 | 10:03 AM
1337240sx's Avatar
how would it be coil if it is always cyl 4 and only cyl 4??? then a minute later cyl 3 starts to miss a fire ever other fire...
Old Mar 31, 2010 | 03:45 PM
A-ron's Avatar
well start with the basics change out
spark plugs
wires
Drifting:
with your pants on.
Old Mar 31, 2010 | 05:23 PM
1337240sx's Avatar
done and done... i have covered the basics weeks ago... i have done everything but replace the motor...
empire came over and did the same thing...
its at a repair shop now. there saying the distrib is bad(my dad brought it there and is paying for it to be fixed before i can get it back to work on it some more)
Old Mar 31, 2010 | 09:47 PM
Super Coupe's Avatar
Old school TR member
Thinking it is the distributor. Its obviously spark related.
Assuming you replaced the ecu? Checked all wires?
Old Apr 2, 2010 | 08:03 PM
Empire's Avatar
buildin' it
any update?
Old Apr 2, 2010 | 08:13 PM
ZenkiLB's Avatar
Finally out of 240 scene!
how much does that shop charge to replace the distributor?
No more POS 240's
Old Apr 3, 2010 | 07:00 AM
180SX's Avatar
if you are dropping a cyl after warm up, it is actually the pickup plate in the dist. There is a 720 fine tooth plate that runs through a optical pickup inside the dist... just like a cam sensor on a SR. This is happening on a lot of SRs / KAs with age.
martin
