350z AC/Heat Idling Issues???
Old Mar 5, 2010 | 03:53 AM
~Boost Freak~'s Avatar
Default 350z AC/Heat Idling Issues???
okay i did a bunch of mods to my Z and one of them has some how messed up my idle when ever i turn on the heat or air odd i know but unless its an extreme coincidence its gotta be a mod issue so heres what i did:
cold air intake (jwt pop)
b&m short shifter
front & rear massive wilwood brake kit (14" front 13" rear)
russel stainless steel brake lines
russel stainless steel clutch line
i think the issue is either something got messed up during the shifter install or the intake is some how messing it up, i check the ribbon cable seems okay and made sure theres no vac leaks and that the mass air was going the right direction, the car runs perfect with the ac/heat off but as soon as i turn it on the idle drops then becomes irratic and if driving when i put in the clutch trys to stall
PLEASE HELP!!
Old Mar 6, 2010 | 03:42 PM
twitch579's Avatar
If its not a B-Series your not gonna get any help here. Try My350Z.com.
04.5 Z33 412/412 Single Turbo. KABOOM!
New car, 2004 YJ GTO - Forged TSP LQ9 370 - Fast 102/102 - Big Cam - Fasterproms
Old Mar 6, 2010 | 05:18 PM
thanks i check it out
Old Mar 7, 2010 | 01:26 PM
sameo2's Avatar
infiniti tech
Any of this mode has nothing to do with your concern!!!!on less u did something wrong wen you install the the cold air intake..
Old Mar 7, 2010 | 04:37 PM
sullivanracing06's Avatar
haha, sorta sad when your falling on tr to look for help for such a new car, only thing i can think of would be a vac leak on your cai, maybe post up some pics and were you ran your emissions/ pvc hoses to on you cai cuz thats the only thing i could think would be fucking up.
hope this helps..
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Mar 9, 2010 | 03:24 AM
no vac leaks have checked and checked i think the issue is the ribbon cable connecting the ac to the main harness i may have damaged it some how when removing to do the short shifter ordered a new one yesterday should be in today hoping that will be the end of the issue
