ka24de headgasket replacement??
Old Feb 7, 2010 | 02:56 PM
rollinondonuts's Avatar
Love all.
Default ka24de headgasket replacement??
I gotta 1992 240sx and im pretty sure it has a blown headgasket...How easy is the head to remove and re install? i dont own a haynes on it but am going to buy one ...Would it need a resurfuce? I have changed the headgasket on D series SOHC honda motors but never a ka24de....Any input will help a ton.
If ANYONE NEEDS ANYTHING TOWED / MOVED IN THE TAMPA AREA PM ME ,ROLLBACK ON THE READY CHEAP!
Old Feb 7, 2010 | 05:29 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
i just did mine a little over a month ago
what i did was pull the radiator/fans,air box,
and i also removed the intake mani the gasket is only $14, it makes it lighter to pick up..
then i pulled off the valve cover and the front timing cover,had a friend with me,then removed the cam bolt for the chain on both cams then ziptied the chain so it doesnt fall,then pulled off all the cam caps and pulled the cams,and the timing gear, losened all the nuts in the order your supposed to the pulled the head off cleaned the head and replace the new gasket then torqued it down put it all back together..look up all the torque specs and even a thread on how to do it,it's easy just time consuming ohh and setting the timing right was pretty shitty thou.
Drifting:
most fun you can have
with your pants on.
Old Feb 8, 2010 | 05:52 AM
Love all.
Yea i figured id have to take off the intake mani...probly exhuast manifold aswell..The timining is what im worried about..Ive never messed around with chains...Did you Turn it to TDC befor pulling the head?
Old Feb 8, 2010 | 07:42 AM
A-ron's Avatar
yea and you can also mark the chain/gears with a marker to help you out..
look up jim wolf ka24de timing thats what i used
Drifting:
with your pants on.
Old Feb 12, 2010 | 07:02 AM
Love all.
Thanks for your help bud im about 35$ away from the replacement maybe tomarow i can get the parts
Old Feb 14, 2010 | 11:51 PM
stage3_rx7's Avatar
I wanna be a baller.
I had to do it on mine once(wide open on bottle down I4 lol)
I did not remove the intake, i just dropped the exhaust manifold then zip tied gears to the chain. removed the head, one side at a time. place in new one the same way(get the copper head gasket spray total life saver) reassemble and turn it over by hand and make sure the cams are on point. copper rtv ftw.
1985 Dodge Conquest-SOLD
1990 Mazda Rx7 GTUs-SOLD
1990 Nissan 300ZX TT-Traded
1993 Nissan 240sx-Traded
1994 Ford Thunderbird SC-Totaled 6/11/10
1990 Nissan 240sx-SOLD
1995 Nissan 240sx se-SOLD
1994 Nissan Altima gxe-DD
Originally Posted by tissimo
No thanks on the rx7, spinning triangles are the work of voodoo.
Old Feb 17, 2010 | 06:02 AM
JR's Avatar
JR
TR Balla Donor Supreme
+1 on the copper headgasket. I plan on using one when I do my rebuild.
Old Feb 17, 2010 | 06:09 AM
A-ron's Avatar
for the copper head gasket dont you have to get the head machined for it??
and why would you go copper the OEM head gasket holds up around 600+ i doubt you will ever see that much power.
Drifting:
with your pants on.
Old Feb 17, 2010 | 08:20 AM
mewantkouki's Avatar
no
oem headgasket =/= 600 hp. Maybe with 11mm arp studs...
Old Feb 17, 2010 | 10:41 AM
stage3_rx7's Avatar
Its just a spray, like a spray sealant? lol
