need help for sr
ok so i have a redtop sr that im changing the t25 to a s14 t28 and im having some problems...
so i bolted the turbo up and have some trans cooler lines for my oil feed and return lines.. and im having a problem. my block i stripped out where the oil feed line goes into so it constinly leaks.... so what can i do to make it stop leaking... |
helicoil it
pull the motor, weld in a AN fitting
JB weld a AN fitting other than that, re drill and tap/helicoil... should i take this as you're not buying my S14 anymore? |
i dont know man and thanks ...
bump...
youve already got your answers...
You can also tap it to 1/4" NPT and use a 1/4NPT to -4AN fitting for your oil feed.
yeah tap it or helicoil it... its pretty easy shit to do... you can buy a single coil kit but its kind of pricey depending on where you get it... it comes with the tap and the coil and shit.. just find out the size of the hole and go to your hardware store and figure out what you need... its honestly Cake..
i did it and it worked thanks guys..... will post up pics of build thread.... thanks....
