ka24de help sos!!!
Old Aug 2, 2009 | 03:00 PM
haitianmarv's Avatar
Default ka24de help sos!!!
so heres the deal my car shut off on me on the highway the other day. So i looked under the hood in the fusebox and saw that the 30a fuse wuz blown and i thought i needed a new battery so i put a new redtop optima in it then it started back up! Ok so then when i got to the atuo parts store i got my old battery charged but they said it wuz good. So i put it back in my car it started right up. Then i shut off by itself after 1 minute, the fuse blew out again when i looked at the fusebox. So i replaced it again then it blewout right while i put in. Long story short that fuse keeps blowingout everytime i put one in so what can it be???
a wire short????????
get at me pleassssssssseee!!!
call or text .... cash in hand if you help out!!!
7273423202
haitianmarv
SIG PIC WAS WAY TOO BIG]
Old Aug 2, 2009 | 03:12 PM
240Cyanide's Avatar
Function is my form.
alternator could be the problem, or the wires for it
i had this problem once and i changed it and it worked fine
Old Aug 2, 2009 | 03:16 PM
RobRobking18's Avatar
call me puppy
just buy a whole bunch of 30A fuses and youll be fine.......you never know if you put another fuse in it it might just go away.
Old Aug 2, 2009 | 03:18 PM
Ph34r's Avatar
ΔxΔp ≥ h
Here is a good place to start...
Old Aug 2, 2009 | 03:31 PM
David48's Avatar
I <3 usdm
With that mindset, you may as well put in a 35 or 40 fuse.
Potato
shit got all davided up.
Old Aug 2, 2009 | 05:00 PM
Petes s13's Avatar
Theres a short somewhere. follow the wires from the ignition, Just un-wrap your wiring harness and see what you find, I wouldnt be surprised if you found some wires melted together. Same thing happened to me.
Old Aug 2, 2009 | 05:09 PM
call me puppy
god you get annoying
Old Aug 4, 2009 | 04:37 PM
JDM Status's Avatar
Original status
agree with pete, i was just having problems with my accessories and fuses blowing in the kick panel. looked at my harness, TONS of things wrong, from bare wires to melted ones.
Tsuda-Ichi
Old Aug 4, 2009 | 06:15 PM
David48's Avatar
I <3 usdm
Potato
