Oil Pan Broken Bolt HELP!!!
Old Jun 10, 2009 | 07:30 PM
chome's Avatar
Will sleep for food.
Default Oil Pan Broken Bolt HELP!!!
While putting in my new oil pan with my welded bung one bolt in the front right corner broke and is stuck in the block. I put in oil in my motor today and it leaks only in that one spot. How can I take that out so I can put in a new bolt?
Thanks for any inquiries.
EDIT: Wrong forum, can a mod please move this to tech section for me.
Old Jun 10, 2009 | 07:37 PM
osama tim laden's Avatar
kings cannot fall.
probably going to have to drill it out, or hope you can turn it out with visegrips or something and retap it.
sounds pretty sucky.
Old Jun 10, 2009 | 07:38 PM
chome's Avatar
Yea I cant grab it with vicegrips since none of it is sticking out.
Old Jun 10, 2009 | 08:23 PM
-Mike's Avatar
Formerly IThaJokaI
use a really small bit to drill into the center, then use a left hand bit to pull it out. Problem solved.
Old Jun 10, 2009 | 09:26 PM
4wheeldriftS13's Avatar
February - Ride of the Month
pray to god, get a screw extractor, if that doesn't work do what Tim said.
RIP Tim Aldrich
Old Jun 10, 2009 | 11:21 PM
sean1's Avatar
i has double turbo
same thing happend to me. drill a small and try to use an extractor but dont break the extractor too. thats what i did and i went through like 20 carbonic tip drill bits getting that out
my honda sounds like a lawnmower, because it is one.
Old Jun 11, 2009 | 05:24 AM
the extractor snapped on me too.. thats why I said pray.
RIP Tim Aldrich
Old Jun 11, 2009 | 06:27 AM
Speed cat's Avatar
speed cat
this shit sucks man. that happend to my last block. you will probley have to re tap as those bolts are so small it makes extremely hard to extract them. PITA man, those bolts dont have to be tightend very hard, just snug them good and your fine, I tighten those things now like their made of hollow glass cus I hate re taping a block, I like having things stay how they were from factory. and just like 4wheel said, If the extractor snaps your f-ed
Old Jun 11, 2009 | 11:37 AM
sean1's Avatar
i has double turbo
yea when i bought my motorset i found mine, idk why ppl tighten them so hard... lower oil pan is what..like 8-10flbs?
Old Jun 11, 2009 | 02:04 PM
chome's Avatar
Going to Sears now to buy the extractor set, will update soon.
