350z axel problem
Old May 2, 2009 | 08:05 PM
Kernon's Avatar
RIP PABLO THE MAN GARCIA
Default 350z axel problem
Ok this is the problem my axel nut on the passenger rear is coming loose this is the
3rd time the nut has come loose. i tighted it twice this last time it trashed the wheel bearing so to the dealer it went, i had to replace the wheel bearing and had the tsb done for the axel why it was out that was last week. Today i noticed it was showing signs of the nut coming loose again . I dont know what to do with it any ideas.
Old May 3, 2009 | 02:28 AM
EludeR's Avatar
Take it back to the dealer and make them fix it. I haven't had any such problems with my Z (or any problems at all).
Old May 3, 2009 | 07:41 AM
180SX's Avatar
had a z33 do this a while back.. Ended up finding a big lock washer to put underneath axle nut.
sometimes the simplest things work the best... hope it does for you
martin
Old May 3, 2009 | 08:31 AM
Empire's Avatar
buildin' it
martin
that's what I was thinkin too...
should be better than trying to loctite it down... green loctite would work, but the lock washer would probably be the better option
Old May 3, 2009 | 08:35 AM
Kernon's Avatar
i did use locktite but never got to c if it work thats when it went to the dealer so
Old May 3, 2009 | 01:37 PM
Empire's Avatar
buildin' it
what kind did you use?
the standard red or blue won't do it... you'd have to use green... purple might have worked...
Old May 4, 2009 | 12:32 AM
Kernon's Avatar
never got to c if it would hold
Old May 4, 2009 | 07:45 AM
lordofthemiasma's Avatar
RIP DJ YOU WILL BE MISSED
Im going to go with the lockwasher idea. that is probably the best, as well as simplest.
RIP my very best friend. DJ aka djzstang1 you will be missed dearly. I love you bro.
1995 240sx se
1992 240sx
1990 240sx se
1991 240sx hicas sr20det MDX
1991 240sx project coupe
1990 240sx drift beater hatch
1993 240sx sr20det
Old May 5, 2009 | 03:38 AM
Durdan's Avatar
No Ants Drift Member
use an impact gun to tighten down the nut, then put another nut on and tighten that one. thats what i used to do on all my 240s so they would never back out again.
double nut like whoah.
RIP Tim. i miss you, buddy
Old May 5, 2009 | 11:20 PM
Empire's Avatar
buildin' it
that's what she said!!
giggity giggity
