S14 questions
Old Feb 24, 2009 | 05:04 PM
nismofiend's Avatar
BMW
Default S14 questions
Is the radiator core support bolt in or weld in and do any of you have a prefered junk yard to go to that has some S14's sitting in the yard? I have some parts that I need to get but Idk where to really begin looking because 240's are somewhat a rare breed to see in junkyards here in lakeland.
240sxs are not investments, you dont make back what you put in... trust me.
Bayerische Motoren Werke
Old Feb 25, 2009 | 04:41 AM
NeedCAforS13's Avatar
TOTALLY AWESOME.
It's welded.
Try the nissan dealership. From what I remember, a new core support wasn't that pricey, and you don't have to try and cut it out of a car.
(O=O/-ROUGH WORLD-\O=O)
Old Feb 25, 2009 | 05:13 AM
Blackzenki82's Avatar
(OO\____/OO)
I'm not sure it's even welded.... i think they either use that heat stamping, or the same epoxy they used for the rest of the frame work....
if you're serious bout replacing it, and for easy of install, I'd spring the extra $$$ and get it from the dealership... t may be more expensive, but you know what you're getting...perfection
repeat post lol.... just saw your post there needCAforS13
Originally Posted by sean1
Shit'll buff out.
Old Feb 25, 2009 | 05:52 PM
nismofiend's Avatar
BMW
Ok, that works, reason I ask is cuz the car that I bought got backed into by a truck, the original owner before me ziptied the lights and what not to keep everything in the front end on. It works, doesnt move or anything, Id just like to replace the core support when I do my front end conversion on it. I work as a tech so Im not scared of doing the work, I just need to know how to do it LoL.
I priced one at courtesyparts.com and its about 400 even.
Do any of you have a friend at a bodyshop that could give me some guiding points on replacing it?
Old Feb 25, 2009 | 05:59 PM
TOTALLY AWESOME.
try reading up on s15 front conversions. i believe a lot of those guys replace their core supports with s15 supports. it should give you a good idea of how it's done.
Old Feb 25, 2009 | 07:03 PM
nismofiend's Avatar
BMW
very cool ca, thanx for hte input, Ill look into that.
Old Feb 25, 2009 | 07:35 PM
longfellow2's Avatar
FORE:sight
Its spot welded in place. I know this because I had to drill them all out recently.
Replacing is pretty simple, there are factory alignment marks you can use to get it lined up correctly. I would just make the new one a bolt in. It makes pulling the motor so much easier.
Originally Posted by Epstein
Old Feb 26, 2009 | 03:17 AM
nismofiend's Avatar
BMW
Well thats good to know, any special type of drill bit that you used?
Old Feb 26, 2009 | 05:52 AM
FORE:sight
They make spot weld bits, but I just use 1/4 inch
Old Feb 26, 2009 | 08:50 AM
nismofiend's Avatar
BMW
Kewl kewl, off to lowes I go
