ka trouble again
Old Feb 1, 2009 | 10:42 AM
torgdor's Avatar
mudgina
Default ka trouble again
ok so i have a 92 240sx and the dam injectors are not working i changed the fuel injectors and the harness and the ecu with 3 def rent ones now idk what it could be has any one ever had this problem and if so how do i fix it
Old Feb 1, 2009 | 10:43 AM
Chris C.'s Avatar
I ♣ Baby Seals.
What makes you think the injectors aren't working?
Old Feb 1, 2009 | 10:55 AM
torgdor's Avatar
mudgina
i have them out and they are not spraying no fuel
Old Feb 1, 2009 | 11:04 AM
Ph34r's Avatar
ΔxΔp ≥ h
Stupid question... but you got fuel pressure?
Make sure the ground from the injector closest to the front of the car is attached too.
Old Feb 1, 2009 | 11:55 AM
IThaJokaI's Avatar
Hates cars...
You've changed everything but the fuel pump and filter... Maybe you should see if your pump is even turning on..
Old Feb 1, 2009 | 12:11 PM
Epstein's Avatar
Retired
Maybe you should check the distributer. If the 4-6pin connector on the base isn't hooked up, the injectors won't fire.
Old Feb 1, 2009 | 12:22 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
listen for ur fuel pump to turn on.
or take a fuel line off and turn the key on to see if there is fuel pumping out.
Drifting:
most fun you can have
with your pants on.
Old Feb 1, 2009 | 01:13 PM
art's Avatar
art
E=MC-hammer
what he said.
IM IN VA BITCH!!!!!!
www.rccustomz.com
