???? On pulling a DOHC out of a 91 ?????
Old Aug 20, 2008 | 08:22 AM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
Exclamation ???? On pulling a DOHC out of a 91 ?????
ok so im pulling a DOHC motor out of my 91 s13 i have everything ready to pull but the question is (where do i hook the chains of the engine lift too) its a blown motor rod came out. if you can get a picture showing where they hook up that would be nice cuz i need to put the newer one in without breaking something.. thanks..
Drifting:
most fun you can have
with your pants on.
Old Aug 20, 2008 | 08:31 AM
Ph34r's Avatar
ΔxΔp ≥ h
just wrap one around the intake mani and one on teh exhaust mani.. or you can get the bolts and screw them into the block and lift that way... they are by the rear of the exhaust mani. Either way, it's a simple job.
Old Aug 20, 2008 | 08:35 AM
A-ron's Avatar
ok i figured on the intake side but not the exhaust side the bolts look like they would break. thanks
Drifting:
with your pants on.
Old Aug 20, 2008 | 10:52 AM
shinmei2006's Avatar
the bolts wont brake trust us. put the bolts (top/bottom) through the chain before bolting it in. then just pump slowly. watch out for the radiator and steering rack
http://www.hashiriya.net
Old Aug 20, 2008 | 11:37 AM
A-ron's Avatar
i removed the radiator it was easy enough.
but look what i found when i took off the heat shield for the exhaust
i always thought that i the #1 cly
http://i339.photobucket.com/albums/n...6/DSCF0145.jpg
but i blew # 1&2 heres my rod hanging out lol
http://i339.photobucket.com/albums/n...6/DSCF0146.jpg
http://i339.photobucket.com/albums/n...6/DSCF0144.jpg
it got a rod knock and i was out of town so i went a far as i could
Drifting:
with your pants on.
Old Aug 20, 2008 | 12:06 PM
"dat'll doer"
damn did you run that bitch with no oil for like a year or something? lol
Old Aug 20, 2008 | 12:24 PM
A-ron's Avatar
no it had a slung rod baering or something cuz when i bought it at 2500 rpm it would lag then as the rpms went up came in gone as it wanted to. only had it for a month did a tune up the fix it didnt work. ohh as it was knocking it is loud and you can feel it in the gas pedal. cazy hope it never happens again.
Drifting:
with your pants on.
Old Aug 20, 2008 | 01:00 PM
how many miles were on it?
Old Aug 20, 2008 | 02:45 PM
A-ron's Avatar
113,xxx i bought it on here from a user name of ((Team Pureimports))
for 1,600 i compression check it when it was warm test drove it the only problem was that it lagged at 2500rpm i thought it was a easy fix guess not. he had to know what was wrong it thats why he sold it he told me the timing chain needed to be replaced. well shit happens. and i cant kick his ass he livess to far away. dont take ur chances with him
Drifting:
with your pants on.
