a/c whoes...
Old Apr 14, 2008 | 01:51 PM
norachelhere's Avatar
fails.....
Default a/c whoes...
So, I'm driving around in a stock SOHC. (keeps me from getting so many tickets) Seeing as how I only paid 800 bucks for it, the AC doens't work. I decided I would dump in some nifty green dye to see if I could find the leak considering all of the parts apear to work. So I unscrew the dust cover/cap. And go to screw on the adapter. Thats when the line completly broke off. Looking at it, you can tell that a part of it was cracked previously and the little bit of stress from srewing the adapter on finished it off.
Not knowing much at AC stuff, I don't know if I need to replace the whole line or if it can be repaired. If it can be repaired, can it be done still in the car, or does the line need to be completely removed?
The break is just before the compressor, a few inches away from where it bolts to the compressor. (great description, I know)
I'll have to see what I can do about getting a picture of it just for clearification.
Thanks for the help
Old Apr 14, 2008 | 02:34 PM
Sohc4now's Avatar
^^^I'm with stupid
take it off and have it fixed or replaced.
replace the o-rings
replace your receiver/dryer.
convert to 134-a
Old Apr 14, 2008 | 02:43 PM
fails.....
^ yeah, I was trying to avoid that much work.. lol. I was just gonna dump in some dye, seal the leak, and fill with r134-a.
I take it I can't just bend the line around, and fix it in the car? Having to remove it, then put it back sounds like it would be a bit of a pain in the ass.
