Can i use 97 Altima Parts in a 94 Altima
does anyone know if i can build a 94 altima exterior with the exterior of a 97 do they fit with no problem. or did the boy style switch over and i cant use it. even the interior can i switch them over.
i believe they are both the rounded style bodies right, if so then everything should line up
It is all the same man . Only dif is obd1 and obd2
used to own an altima, yes the body panels match up.
You can find a ton of parts from junkyards across the bay. |
