speedo question
Old Nov 2, 2007 | 08:58 PM
asia989's Avatar
Why So Serious?
Default speedo question
on my sr harness there is no yellow/green wire for my dash plg to attach to? what other wire could i tap to get a signal? also my odometer doesnt work as well
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Nov 3, 2007 | 07:36 AM
asia989's Avatar
Why So Serious?
anywho....
Old Nov 3, 2007 | 08:10 AM
norachelhere's Avatar
fails.....
the wire is there, its probably just a different color... your odometer won't work without the speedo signal. you're just gonna have to follow the wire from the sensor itself and fill in the blanks as you go...
Old Nov 3, 2007 | 04:41 PM
4wheeldriftS13's Avatar
February - Ride of the Month
My coupe did the same thing I want this answered.
RIP Tim Aldrich
Old Nov 3, 2007 | 06:50 PM
Epstein's Avatar
Retired
Just to clarify for you guys, the speedo gets it's signal directly from the speed sensor. These wires (y/l, y/b) connect at the passenger side relay box and wind around to the cluster by going in front of the radiator and up through the SMJ. The yellow/green is the speedo OUTPUT, which tells the ECU how fast you're going.
If your odo doesn't work, make sure the small white connector on the lower, back area of the cluster is connected firmly. The speedo's needle and the odo servo are driven from the same control board.
It's not uncommon for the wire to be missing on a used harness. Removing it effectively performs a speed limiter removal (and also makes your car more prone to stalling at lights). Find a pinout for the ECU and locate this pin position. If theres nothing there, you might be able to steal a pin from an unused function or another harness.
Old Nov 3, 2007 | 07:52 PM
asia989's Avatar
Why So Serious?
wth is your number so i may i ask you things in the future so i jus gotta check the connections on the back of the gauge cluster?
Old Nov 3, 2007 | 07:56 PM
Joe, your new turbine got you home that fast? lol
RIP Tim Aldrich
Old Nov 3, 2007 | 09:53 PM
asia989's Avatar
Why So Serious?
yesh the lil hondas that were going to CCC saw a white blurr followd by whistles
