Radiator removal and installation..
Old Jun 9, 2007 | 05:20 AM
kober's Avatar
Don't Drink And Drift
Default Radiator removal and installation..
okay.. i know this might be a newbie question.. but what do i have to take out.. from what i see.. i have to take out the e-fans, cold air intake, maybe the battery and some other little parts..
anyone done it before? and know what to take out and etc so i dont f up too bad.. k thanks
Old Jun 9, 2007 | 05:58 AM
cagedeyecam's Avatar
AERODYNAMIC WHEN I FIGHT
s13 or s14? you have to remove the radiator upper and loer hoses, intake , and maybe the overflow resevior. not the battery. ohh yea and e fans.
Old Jun 9, 2007 | 06:34 AM
kober's Avatar
s13
Old Jun 9, 2007 | 06:59 AM
BluRRboSi's Avatar
35.5 psi, stock sleeves
two 10 mil. nuts on the brackets, and the hoses and its that easy.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Old Jun 9, 2007 | 09:02 AM
marble hatch's Avatar
i can has 30r plz?
ok
step 1-remove intake
step 2-remove fan shrouds
step 3-undo upper and lower radiator hose clamps and remove hose from overflow tank
step 4-remove 2 10mm bolts from radiator brackets on the front radiator support (use wd40 or go slowly beacause they tend to be rusted out and break off)
step 5-remove radiator by lifting up (being careful not to beat it up to bad..)
and there you go your radiator is out ive done it a bajillion times and its the same every time lol
~edit~ unplug your efans also but you dont have to take them off of your radiator..
(O=O/-180sx-\O=O)
Old Jun 11, 2007 | 04:53 AM
norachelhere's Avatar
fails.....
becareful when you are taking it out/ putting it in, its really easy to drag it against stuff and run the risk of messing it up.
its not that hard of a job to do, you just have to be careful
Old Jun 11, 2007 | 05:33 AM
kober's Avatar
k thx everyone
Old Jun 13, 2007 | 12:11 AM
danzel's Avatar
just be careful removing the parts and installing it..signs of a Nissan radiator hose beginning to fail, is cracking, and the obvious a leaking radiator hose. if your radiator hose shows signs of wear from cracking, you need to replace the hose immediately. if this is the case it is good practice to replace all the hoses in your Nissan engine.
Old Jun 13, 2007 | 05:54 AM
fails.....
i'd say replace them anyway... you're gonna be down there already and its better to be safe then sorry
