timing!!!
Old Apr 24, 2007 | 01:24 PM
etnies678's Avatar
Default timing!!!
Does anyone know how to adjust the timing for a 93' KA24DE?
Old Apr 24, 2007 | 02:00 PM
norachelhere's Avatar
fails.....
what exactly are you trying to adjust? spark timing? lossen the two bolts on the dist., turn it, and tighten bolts.
Old Apr 24, 2007 | 02:05 PM
fails.....
oh and before you get flamed for asking a really common question, go to goodle and search for 240sx timing
have fun
Old Apr 24, 2007 | 04:16 PM
dan's Avatar
dan
Get the fuck off my lawn
start car, let it get to operating temp.
pull TPS plug (just the main one, not the switch --- for auto cars/obd-2)
adjust idle via screw on back of intake manifold to within 750 rpm idle (+ or - 50 variance).
loosen distributor, hook up timing light.
check timing. adjust as needed. stock is 20* (stock sr is 15*).
bolt dist. down, plug tps back in. drive.
Old Apr 25, 2007 | 09:44 AM
fails.....
there you go. couldn't get more simple or accurate. and it saved you some searching.
have fun
Old Apr 25, 2007 | 01:22 PM
etnies678's Avatar
Thanks!!!
