Ka ?
Old Apr 24, 2007 | 10:31 AM
QK94SC2's Avatar
Default Ka ?
I have a 95 s14 KA24de engine/wiring harness/ecu can i use it in my s13 or do i need a s13 wiring harness and ecu?
Old Apr 24, 2007 | 10:45 AM
norachelhere's Avatar
fails.....
you ought to be just fine.
I don't remember if anything is different between the s14 harness and s13 harness....
I know you can put a s14 engine in an s13 and use the stock harness....
if you have the harness and ecu, then use it.
Old Apr 24, 2007 | 11:43 AM
170k240's Avatar
Will Drift For Tires
you should just give me the ecu
Nissan North America - Canton
Old Apr 24, 2007 | 12:11 PM
fails.....
the ecu's are the same aren't they...
i don't know why, but i can't remember shit today....
Old Apr 24, 2007 | 06:22 PM
170k240's Avatar
i would like you to give me the ecu, because i need a spare. buuuuuut, im pretty sure you need all that shit to do a complete swap. i cant really remember either.
something in the back of my mind is telling me you would be fine using the harness and ecu you have now and putting that motor in, buu im not sure. search ka-t.org
Old Apr 25, 2007 | 09:39 AM
fails.....
ok, i just confirmed it, my buddy, when he blew his motor the first time, swapped in a 95 ka. he used his ecu and harness. he just put in his dist. The s14 dist. has the coil inside it, thats what the difference is. so if you want to use your s13 harness and ecu, then you have to use the s13 dist.
good luck with the swap.
Old Apr 25, 2007 | 09:43 AM
170k240's Avatar
there ya go, now lemme have the ecu. seriously
Old Apr 25, 2007 | 10:00 AM
QK94SC2's Avatar
Lol i need teh ecu so i got a car to drive. Yea i hope everything goes smoothly we just got done doing and s14 sr so i got everything from the KA to swap in my s13~
