problem with sr coil pack ground
Old Apr 1, 2007 | 07:14 AM
SLOW240's Avatar
welder/fabricator
Default problem with sr coil pack ground
as it says im getting power and signal to the coil packs just not a ground... what could it be........ the coil pack is grounded to the motor but still no spark
WELDER AND METAL FABRICATOR
http://www.myspace.com/welderfabricator
Old Apr 1, 2007 | 10:01 AM
chome's Avatar
Will sleep for food.
ecu problem maybe
Old Apr 1, 2007 | 12:27 PM
sameo2's Avatar
infiniti tech
i got the same concern and rpl the ignator(power transistor)that fix my problem.
Old Apr 1, 2007 | 12:52 PM
SLOW240's Avatar
welder/fabricator
the little igniter chip? that has a plug on each side?
Old Apr 2, 2007 | 06:09 AM
Durdan's Avatar
No Ants Drift Member
the coilpacks dont ground to the head when theyre bolted down. make sure you have the ground wire coming off the back of the coilpack harness bolted to the head
RIP Tim. i miss you, buddy
Old Apr 2, 2007 | 07:44 AM
SLOW240's Avatar
welder/fabricator
the ground is bolted to the back of the head thats whats meking me curious of what it could be
