vacumm line question
Old Mar 6, 2007 | 12:38 PM
SgtSixer's Avatar
the general
Default vacumm line question
i'm in the process of doing a single to dual cam swap and i have 4 loose vac lines coming out from underneath my throttle body, can anyone tell me where these lines go? 1 runs to a plastic t and has a second line coming off of that. and 1 is a larger diameter then the other three.
any help would be appreciated
"If you take advantage of her, you will burn in a special place in hell.... a place reserved for child molesters and people who talk in the movies...."
Old Mar 6, 2007 | 01:59 PM
Epstein's Avatar
Retired
Cap all of them off unless you want to keep emissions crap. You just need one line from the back of the intake manifold to go to the fuel pressure regulator. That's it.
Old Mar 6, 2007 | 06:40 PM
170k240's Avatar
Will Drift For Tires
they go fom egr shit to your charcoal canister. they can all be capped. (the ones in the front under the TB that is)
Nissan North America - Canton
Old Mar 6, 2007 | 09:51 PM
norachelhere's Avatar
fails.....
they can be capped if you remove your emissions crap.
my suggestion, take the intake manifold off so you can follow the lines and what not and completely remove what isn't needed. and cap things off better. less risk of mistakes that way... or at least it was for me....
have fun
Old Mar 7, 2007 | 10:55 AM
170k240's Avatar
yeah, i could have wnet into more detail but it would be an essay of insturctions
Old Mar 7, 2007 | 04:53 PM
SgtSixer's Avatar
the general
so i looked into it some more, and apparently all i need are 3 vac lines i only know two, fpr and brake booster. anyone know the third?
