TPS help on pulsar swaped sentra
Old Jan 27, 2007 | 03:01 PM
luvsracin87's Avatar
turbo hhhmmmm?
Default TPS help on pulsar swaped sentra
the car is a 93 sentra with pulsar sr20det swap. i need to know what the TPS voltage should be at WOT and with the throttle closed. if anyone could help rep will be givin. thnks
Steve: (813) 810.4146 <~ call or text
Old Jan 28, 2007 | 02:35 AM
turbo hhhmmmm?
some one???
Old Jan 28, 2007 | 07:44 AM
crash course84's Avatar
the tps voltages are going to be the same as any other sr (.45 closed throttle~4.5 open throttle). did you switch the outside two wires (since the gti-r tps actuates in reverse from a normal sr).
-kenji
Old Jan 28, 2007 | 10:11 AM
turbo hhhmmmm?
i didnt do the swap, so i dont know if the wires where switched.but the car ran fine before he put a new TPS on(which is why i think it needs to be adjusted) and now when you go to jump on it the car will start to go then act like it hit a brick wall.
