couple ?? about sr20det
Old Jan 12, 2007 | 06:13 PM
ekcoupe's Avatar
IS FASTER THAN YOU
Default couple ?? about sr20det
i just got a 93 s13 with an sr20det with a T28 skyline turbo..
1. My boost is 7psi low and 13psi high.. shouldn't i be able to boost higher than that somehow..???
2. When i put it on 13psi it likes to detonate, I can do 12psi safetly any suggestion or answers..??
Really need help i want to make this car perfect i just got it yesterday..
Old Jan 12, 2007 | 07:28 PM
norachelhere's Avatar
fails.....
yes you can boost higher than that...somehow...
it detonates at 13 psi so either get a higher octane, or retard the timing, but at that point, you might as well turn the boost down a little bit.
sorry about the sarcasim.
if you are looking to gain some knowledge, 240sxforums.com is a great place to start. Read every sticky you can find on that site. Those stickies will answer most of your questions.
good luck
let us know how it goes.
Old Jan 12, 2007 | 07:30 PM
ekcoupe's Avatar
IS FASTER THAN YOU
ok thanks alot man....
Old Jan 12, 2007 | 07:59 PM
DriftingDJ's Avatar
240LSX
I suggest getting a rom tune at XAT with some 550cc injectors and a z32 mafs. You are all maxed out.
