Question about a 240sx water pump.
Old Nov 15, 2006 | 03:02 PM
JDMbyBlood's Avatar
Default Question about a 240sx water pump.
Today I noticed some coolant on the ground. Looks to be leaking up under the water pump. I suppose that is the sign that the water pump is bad or going bad. How involved is it to replace? Does the radiator have to be removed to give you more room to replace the water pump. Thought I would check with you guys before starting the replacment. If it matters, its a 93.
Thanks..
Old Nov 15, 2006 | 03:23 PM
RubberBerner's Avatar
Sideways Maffia
if you have a factory clutch fan and shroud, you'll have to remove the shroud, and the fan is on the pump...of course you'll have to transfer that. but other than that, its just 4 or 5 bolts into the block. should take 20 maybe 30 mins for your first time.
Keep your dog away from the coolant...unless you want to get a new one.
NOBAMA!
Old Nov 15, 2006 | 04:09 PM
Shadytrixta1's Avatar
has whippled VTEC
its not to tough to replace. if you need some help shoot me a pm. ive done 5 water pumps on a twin cam ka in the past 3 months,lol. let me kno
Old Nov 15, 2006 | 04:20 PM
170k240's Avatar
Will Drift For Tires
ill sell you one from a 91 ka, same thing, works fine, $15.
Nissan North America - Canton
Old Nov 15, 2006 | 05:06 PM
JDMbyBlood's Avatar
Thanks for the help guys....
170k240, thanks for the offer, but I think I'll install a new water pump just to be on the safe side. Thanks again for the offer.
Old Nov 22, 2006 | 05:31 PM
CFP_IVAN's Avatar
CFP was...
make sure you lose the belt also.
Old Nov 23, 2006 | 04:26 PM
JDMbyBlood's Avatar
Im not really sure whats going on now??? Car did not leak untill I replaced the rad. cap. I put back on the old cap and no leak. Put back the new cap and it leaks from the water pump area. Im thinking maybe 2 much pressure is building up and causing the leak. What do you think? The reason I replaced the old cap was that its seems to have a slight leak on top of the cap.
Old Nov 23, 2006 | 06:48 PM
Sideways Maffia
well too much pressure will most likely make your reservoir level higher, and will make the weakest part of your system leak. water pump is usually less than $30 new. Might as well make sure you have the right cap (check manual for psi 16-18 probably) and replace that waterpump before it gives you more problems.
NOBAMA!
Old Nov 24, 2006 | 07:05 AM
has whippled VTEC
Where exactly is the water pump leaking?The weep holes?
