Wheel bearing?
Old Aug 7, 2006 | 11:37 AM
D-Roll's Avatar
Blasian Sensation
Question Wheel bearing?
So I go to get my alignment and find out I need to replace my right rear wheel bearing. I just ordered the wheel hub with bearing. I need to know where to go to get the stubs pressed out of the old hub. Any suggestions?
Old Aug 7, 2006 | 01:12 PM
ZXTT's Avatar
A$$hole
If you mean the studs for the lug nuts just put an old lug nut on and smack it with a hammer, hit it square on and it will pop out. I had to do that to my parts car when I was in a bind and was able to reuse them, putting the old lugnut on saves the stud itself......if thats not what you meant then forget I said anything
I just spent 330 getting a new wheel bearing overnighted to me and found out I didn't need it, was special order so I couldn't return it either.....that sucks
Originally Posted by Automobile Magazine
The 300ZX Turbo is a dance; it's a song; it's rolling, roaring automotive art. There is no color that doesn't suit it. There is no mood-lifting chemical substance it can't replace.
Old Aug 8, 2006 | 04:27 AM
D-Roll's Avatar
Blasian Sensation
Thanks for your input, if I can do it that way that will save me $22. That's what a shop wants to charge me to push out the studs and press them into the new hub. Do I need an impact gun for this job?
Old Aug 8, 2006 | 07:11 AM
ZXTT's Avatar
A$$hole
No, you can pull them back through the new hub just by lining them up properly and tightening them down with a lug wrench. I never use impacts for that so you don't screw up the studs or over torq and snap them. once you get them started use a torq wrench to tighten them to spec
Old Aug 8, 2006 | 10:59 AM
D-Roll's Avatar
Blasian Sensation
Ok thanks bro, I got a link to the FSM and see that its simple.
Originally Posted by Mars_302
where did you order your hub from? All the hubs ive ever ordered from autozone and what not already come with new studs.
I ordered the hub from Auto Parts Warehouse | Discount Auto Parts - Get Free Shipping - Auto Accessories - AutoParts - Performance Parts
Old Aug 10, 2006 | 06:18 PM
D-Roll's Avatar
Blasian Sensation
Issue resolved, easy removal and install of the wheel hub with bearing. Case closed.
