E brake light on???
Old Dec 9, 2005 | 04:14 AM
memole's Avatar
Default E brake light on???
hey everyone.. was wondering if anybody knew off the top of their heads why the brake light in my cluster would come on and stay on. I checked the fliud in the master cyclinder (by the way car is 1993 240 H/B 5speed) and its full.. the only thing is that when I giggle the e brake the light flickers and sometimes turns off. is there a sensor somewhere that I could diconnect to get rid of the light in the cluster. thanks all
Chris
Old Dec 9, 2005 | 05:42 AM
Epstein's Avatar
Retired
There is a single wire (yellow/brown?) attached to the base of the e-brake lever. This is the signal to the e-brake light. You'll have to remove the center console to get to it. It should take you about 10 seconds to figure it out once you see how it works.
Old Dec 9, 2005 | 05:43 AM
RubberBerner's Avatar
Sideways Maffia
probably the switch is either loose or (can't remember if the ground is right there or not) ground is losing connection.
NOBAMA!
Old Dec 9, 2005 | 06:39 AM
Chris C.'s Avatar
I ♣ Baby Seals.
Originally Posted by memole
...the only thing is that when I giggle the e brake the light flickers and sometimes turns off...
For some reason, I don't think laughing at your e-brake will do anything.
+1 on checking the little mechanism at the base of the lever. It may be getting stuck, normal wear and tear...
Old Dec 9, 2005 | 10:36 AM
memole's Avatar
ok thanks for the info I will take a look at it and see what the deal-e-o is
Chris
Old Dec 9, 2005 | 04:18 PM
Rey's Avatar
Rey
that means the car blew a headgasket and it's only good for parts... i'll give ya 50 bux for the car
... LOL...... J/K
+1 on Epstein's suggestion
Old Dec 10, 2005 | 04:23 AM
memole's Avatar
that ucks about the head gasket... I just did all the body work and painted tha car..... but if 50bucks is all I can get for it...(grin) thanks guys for the help..it was just a bad ground.
Chris
