Aem Wideband o2 question
Old Nov 2, 2005 | 03:51 PM
fearlessaltima's Avatar
Default Aem Wideband o2 question
am I gonna get a check engine light when I install this sensor since I do not use the oem plug in. what do I do .
Old Nov 2, 2005 | 04:02 PM
DETriment's Avatar
Get off my lawn
remove your check engine light?
-Nate-
[xbox360]DETrimentS14[/xbox360]
Old Nov 2, 2005 | 04:07 PM
well do you have this same product. do you know for a fact .man I have looked on every nissan fourm and nobody will answer my question
Old Nov 2, 2005 | 05:14 PM
dan's Avatar
dan
Get the fuck off my lawn
you can use 1 20 ohm inline resistor (or 2 10ohm's) inline with the old plug's harness. thats what i did, i have a different wideband buti t should be the same.
either that or yeah you'll have to either weld a 2nd bung in to run the stocker, or just remove the CEL bulb.
Old Nov 2, 2005 | 05:39 PM
I'm Phucked's Avatar
army pilot
^ what he said. or you can go with one that sneds a narrow band signal to the ecu to keep things in check. there are a few out there unless you already purchased the aem.
In a relationship you are either man or woman choose wisely [fortune cookie @ Ling's garden]
Originally Posted by Tackleberry
thats an insult to a circus
Old Nov 2, 2005 | 06:14 PM
RubberBerner's Avatar
Sideways Maffia
couldn't you just tap out the EGR bung for a regular narrowband 02 sensor? easier than welding a whole new bung on. and if its the stock cast iron manifold...those things suck for welding!
NOBAMA!
