egr removal?
Old Aug 12, 2005 | 07:23 PM
agent93's Avatar
Default egr removal?
ok i have a opening on my intake box that free air flows through. well, when the egr releases air back into my intake piping, some also flows out of this opening in my airbox. not really a problem, its just that some traces of oil and sludge are going out along with it. so the right side shock tower of my engine bay is regularly tinted brown because of this. i was just wondering, can i remove my egr system to remedy this problem? or could i unplug the hose going into my airbox from the egr, and re-route it to point into a spot i dont mind getting dirty? or is it necessary that it conencts back into the intake stream? i know how these systems work, i just wonder if maybe my idle or something would be effected if the egr system were no longer feeding my intake stream. or if i would have any problems in general if i completely removed it. thanks in advance.
Old Aug 12, 2005 | 07:53 PM
osama tim laden's Avatar
kings cannot fall.
take everything out associated with it, plug hole in exhaust manifold with whatever fits. (i cut the pipe, flatened it out, and then filled in the rest with a welder. not the best way, but hey, it worked.)
cover hole in airbox, or switch to cone filter.
Old Aug 13, 2005 | 02:38 AM
ph0tek's Avatar
Ni-Ten-Ichi-Ryu
Couldnt you just put a air breather on it?
And be done..
Buying/Selling on TR is like shaving your ass before going to prison. You know your gonna get fucked, you just try and make it as pleasant as possible.
Old Aug 13, 2005 | 06:06 AM
kings cannot fall.
why still have it at all?
it wont help.
get rid of it.
Old Aug 13, 2005 | 06:42 AM
DrftDmn's Avatar
look ma , no hands!
Egr= Ewww
Top speed is nothing .... Acceleration , now thats a thrill!
Old Aug 13, 2005 | 09:41 AM
Projex240's Avatar
Take th whole system off is the bast thing to do. If you dont , some people leave the vac line that runs to the egr still hooked and and it can make the car idle and act funny. It doesnt happen all the time, but it does happen Take it off completely and make a little plate to bolt on over the big openening, or buy the plate premade on ebay. MAke sure too, that when you do, you close up the hole that will now be open in your exhaust. They make big bolts for it.
Old Aug 13, 2005 | 10:07 AM
kings cannot fall.
some spark plug non-foulers work to plug the hole also.
Old Aug 13, 2005 | 08:58 PM
agent93's Avatar
thanks for the feedback. it will also be nice to have the little extra space in the bay. ill take a closer look at it tomorrow when i have the time. and ill try to pick up a premade plate just so the removal looks nice and clean
Old Aug 13, 2005 | 10:41 PM
LongFellow's Avatar
Please hold...
Nickel works in the exhause mani... just get a nickel and stick it in the whole vut the pipe off the nut and screw it back in there works perfect.
Team White Car 2010
