help! still having trouble
Old May 30, 2005 | 08:35 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
Exclamation help! still having trouble
i cant get my car to start. its a 91 240 with a ka24de. i just got new wires for it cuz the old ones were melted on the plugs. idk, whenever i turn the key i can tell its close to starting. you can hear the exuast note a little, so i geuss its getting gas. i think it needs a headgasket, but would that matter if im just tryin to start it? it used to start but i took off the valve cover to look at some stuff and now it wont start. whenever it did start the revs would loaf around alot. if driven for a few minutes it, the water would start boiling in the eng coolant tank. and then it wouldent start after that. could this be a timing issue? i looked at the dipstick and theres no water in the oil. so im lost. im just tryin to get this car to start so i can move it about 2 miles away. ill try to get more details on it later. please help, thanks.
Old May 31, 2005 | 04:25 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
help would be...
...helpful?
Old May 31, 2005 | 04:31 PM
Durdan's Avatar
No Ants Drift Member
1st off. ... tripple check your firing order. 1 - 3 - 4 - 2
second off, if its boiling the water that quickly, it obviously has a cooling issue. perhaps bad enough to shit your headgasket. it might be too bad to start.
RIP Tim. i miss you, buddy
Old May 31, 2005 | 04:37 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
damn, thats sucks to hear that. shuan from cfp is comin to check it out tomm. hell know.
Old Jun 1, 2005 | 07:12 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
it was a simple timing problem. fixed in like 25 minutes. all i need now is a s14 valve cover and a water pump.
Old Jun 1, 2005 | 07:25 PM
EludeR's Avatar
What are you going to do with it ? swap a S14 KA in ?
Old Jun 1, 2005 | 07:51 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
hehe, get this. im dumb i didnt know it was an s14 engine to start with. im so happy. this motor prob has like 60k on it. sean said it was a clean swap too.
Old Jun 2, 2005 | 04:45 AM
Durdan's Avatar
where did you get the motor from? does it have the S14 distributor on it? who did the swap?
Old Jun 3, 2005 | 01:52 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
i didnt get the motor, it was already in there. im not sure if the distibuter is s14 or not. sean said it looked like xat did it.
