S13 Silvia corner light?
Old May 19, 2005 | 04:49 AM
J-Dizzle's Avatar
Still Addicted to Boost
Default S13 Silvia corner light?
ok , my conversion is being put ogether as we speak as well as about 2k in other damages but as im looking at my corner light..theres 2 spots for bulbs but only one wire that i can find , the one that went to the fender reflector light on usdm front...now is it like thwe headlights were 2 bulbs can p,lug into to one conector and then into the light wiring? help me out ehre guys , i couldnt find anything in searches...
Don't Text And Drive
Old May 19, 2005 | 07:31 AM
J-Dizzle's Avatar
if anyone has any pictures it would help emensly.
jason
Old May 19, 2005 | 09:21 AM
craig_302's Avatar
boostmonkey
The plug that went directly to your old sealed beams for the headlights will plug right into the silvia lights. As for the side markers, it is up to you on how you want to wire them. For my last sil fronted 240, I got a little creative and jumped the rearmost lights in the corners to the turn signals in the front (ie they only turned on to flash with the front turn signals) while I just ran the stock wiring from the fender to the forward lights.
If you're unsure about what any wire does, grab a multi-meter or even a simple test light and test the wires. Also, if you're missing any of the bulb holders, they can be scavanged off of pretty much any Nissan that has 194's as bulbs for side markers. Just pay attention to the pattern for how they slot into the physical housing.
Old May 19, 2005 | 09:29 AM
craig_302's Avatar
boostmonkey
One of my previous posts has some wiring info in it: https://www.tamparacing.com/forums/s...d.php?t=184008
Not really sure what you're after, but I hope any info helps.
Old May 19, 2005 | 09:32 AM
J-Dizzle's Avatar
thanks...i already knew about the headlights ,plug and play..it was just the corners i had questions about
Old May 19, 2005 | 09:36 AM
J-Dizzle's Avatar
and i had planned on the fogs the same way u did, thanks for the help
jason
Old May 19, 2005 | 09:50 AM
craig_302's Avatar
boostmonkey
No prob, hope everything works out.
