dash lights
Old Apr 7, 2005 | 05:27 PM
freakinrican69er's Avatar
Default dash lights
the dash lights on my altima arent working.i checked all the fuses whats another possible cause for this>?
Old Apr 7, 2005 | 05:35 PM
truffle_shuffle!'s Avatar
Chomsky with dick jokes!
Check relays and check the actual lights behind the display. Go through everything systamtically and you should find your demon.
There are points in life where one looks at his or her situation and says "how the fook did i get here?" ... this is one of those instances....
Old Apr 8, 2005 | 12:21 AM
aight.thanks
Old Apr 8, 2005 | 01:09 PM
asia989's Avatar
Why So Serious?
tcu box...
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Apr 10, 2005 | 03:40 PM
ImportCorner's Avatar
drifting in a lot near u
it happend to me check your grond behind the cd player mine went bad when i swap the radio out and i grounded it to the metal behind it and they came on
Old Apr 12, 2005 | 07:32 PM
VitaminT's Avatar
I don't know about an Altima but on most cars, and the 240, the tail lights and cluster lights are on the same circuit so if you have a tail light out you will know. It won't affect your brake lights just the rear parking lights. Check your tail light fuse and also to see if your tail lights work.
Old Apr 13, 2005 | 02:46 PM
thanx for all your help.but i had the wrong fuse in the spot where the tail light fuse goes and burned up the wire.
Old Apr 13, 2005 | 02:56 PM
VitaminT's Avatar
Um you aren't by chance trying to use a JDM cluster harness are you?
Old Apr 13, 2005 | 02:57 PM
VitaminT's Avatar
Never mind I forgot you didn't have a 240. I tried using a JDM cluster harness on my 240 and it did that. Didn't blow the stock 15a fuse but started melting the wires and stuff.
Old Apr 14, 2005 | 08:47 PM
mine ddnt blow the fuse but it did melt the wires
97blkz
Feb 16, 2004 09:32 AM
94DOHCDELSOL
Oct 30, 2003 03:02 PM
