Tips or Tricks or DIY on Manifold and Turbo gaskets?
Old Mar 20, 2005 | 07:07 AM
_Charles_'s Avatar
formerly 'RiceRocket'
Default Tips or Tricks or DIY on Manifold and Turbo gaskets?
I might attempt to replace the Exhuast manifold and Turbo gaskets myself (SR20DET), seeing as how I had done it on my Turbo Civic many times. Any tips, tricks, or DIY instructions out there? Any special tools I may need?
Charles
My Blog: www.HotRodCaddy.com
Old Mar 20, 2005 | 07:53 AM
Epstein's Avatar
Retired
The turbo and manifold come off as one assembly. You really need to remove the O2 housing to get it out. Removing the turbo inlet will allow you to get to the oil and water lines easier. The water line on the back of the block sucks. Use WD-40 to get it to slide on and off easier. You may have to remove the oil separator (black can on the back of the block) and unbolt the dipstick tube. There are 2 nuts on the manifold that are located below the runners, in the middle. I've found that a 14mm/12mm extended double box end 12-pt wrench from Craftsman to do the trick. Finally, the manifold and turbo are kinda heavy.
Old Mar 20, 2005 | 08:43 AM
Matt Vassallo's Avatar
lifelong learner
and if you have A/C lines - be prepared to tear them / damage them pulling the turbo out depending on how crappy of an a/c hose job the previous person did.
rest in peace tim.
Cronic
Feb 21, 2005 10:04 AM
