SR20VE in a S13?
Old Nov 20, 2004 | 12:59 PM
stockstang's Avatar
The Pit Stop
Default SR20VE in a S13?
First things first will this work? Are the mounts on the block in the same place? Obviously the intake manifold is backwards, so would I just be able to throw a DET manifold on it. To my knowledge this motor was not made in any RWD cars. These are just the most obvious problems I noticed. Thanks
Old Nov 20, 2004 | 03:06 PM
nak1's Avatar
It can be done.... but its frankenstien... Big tom on Sr20deforums is doing a RWD VE right now. Take the head off a VE and put it on a N/A RWD SR20 block. Im sure that is oversiplified but it can be done.
Old Nov 20, 2004 | 03:39 PM
stockstang's Avatar
The Pit Stop
So I assume that the reason you have to swap the head is because the mounts don't work out. I guess I would also have to have a custom header made.
The Pit Stop
8136016962
Old Nov 20, 2004 | 04:47 PM
Blueboost's Avatar
towards antisocial
the VET only came AWD but supposedly DE transmission bolts up to the VE as they are the same block, just a different head. I would have to assume the rwd tranny will mate.
Old Nov 20, 2004 | 07:24 PM
osama tim laden's Avatar
kings cannot fall.
no. it wont.
distributor hits the firewall, nothing fits blah blah blah.
just get a det.
or a fwd car.
Old Nov 21, 2004 | 10:08 AM
nak1's Avatar
well... think about it. You couldnt take an Avenier motor and put it into an S chassis. Nor could you take an S13 motor and put it in a B chassis. So yeah.. the head is what makes a VE a VE... and some other things that are similar between VE's and DET's. All in all it seems like alot of work... only reason i went VE in my B14 is because our transmissions are weak. The S chassis trans are much stronger... go with boost. Its cheaper. Unless you are just trying to get some originality points.
As for a VET that someone mentioned.... its close to impossible to find. And all VE's came with 6 speed CVT trans, but the DE trans bolts up just fine. I have a VE in my B14.
Old Nov 21, 2004 | 10:15 AM
Blueboost's Avatar
towards antisocial
Originally posted by dr. octogon
no. it wont.
just get a det.
or a fwd car.
interesting. kinda shitty though. I'd much rather do a RB25 anyways if it were my $$$
Old Nov 21, 2004 | 10:34 AM
stockstang's Avatar
The Pit Stop
I'm just mainly considering this swap because I want to be oroginal. Never thought about the dizzy. I need to do some more research.
The Pit Stop
8136016962
Old Nov 21, 2004 | 11:29 AM
kings cannot fall.
being orignal is is expensive, and requires alot of shit not working.
but go ahead, do whatever.
