Engine mounts
Old Oct 26, 2004 | 09:25 AM
Turboaltima's Avatar
Question Engine mounts
i was just wondering how, hard/easy, is it to fix engine mounts, whether it tightening, or to replace them, because my car vibrates way too much when its in idle, im pretty sure that is the only problem, that i can think of, my car is a 93 altima, if anyone can help please do, Thanks.
Old Oct 26, 2004 | 10:09 AM
sil8ty's Avatar
The Hebrew Hammer
Most of the time it is a bolt thru or to the engine mount that is tightened/loosened. Depends on the car, but most are the same principal : A rubber and metal mount from the engine to the chassis.
< < < < < PANDA FINGA!! > > > > >
Old Oct 26, 2004 | 11:26 AM
buck19's Avatar
Forever Broke Nissan
you should try changing your spark plugs, the oil, and clean out the injectors, maybe time for a new filter.
when my truck is do for an oil change it usually gets idle shakes. my honda did that a couple of times.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Oct 26, 2004 | 05:47 PM
Cool, thanks guys, well i changed the oil, and spark plugs, so hopefully its just the mount and nothing else, again, thanks alot
Old Oct 27, 2004 | 01:29 PM
well, thanks for the input Dan,im pretty sure its the mount for the transmission, cause ive got 3 mounts, one in the front, back, and the right, the sounds and vibrations are coming from the right one which im sure is the transmission, so hopefully ill get it taken care of soon, and now i think my cv joints are going too, damn.
Old Oct 28, 2004 | 02:07 PM
osama tim laden's Avatar
kings cannot fall.
just buy a new car.
Old Oct 28, 2004 | 02:10 PM
sil8ty's Avatar
The Hebrew Hammer
Originally posted by dr. octogon
just buy a new car.
Old Oct 28, 2004 | 04:08 PM
well, i would but, dont you think it would be cheaper to fix it, dont get me wrong i would love to buy a new car, i just dont have the money, heeey, maybe you guys could start a fund raising event for me, jk, un..less you really want to, anyway, thanks for the input.
Old Oct 28, 2004 | 06:53 PM
kings cannot fall.
no. get a better job.
then, buy a new car.
problem solved.
Old Nov 3, 2004 | 08:21 AM
good point, i guess ill just have to do that then.
