Tuning question for you Nissan tuners
Old Sep 30, 2004 | 03:45 PM
StinkyZ's Avatar
Default Tuning question for you Nissan tuners
This question is for any of you guys that tune ecus. What process do you go through to tune the timing maps. I dont mean altering the chip itself but how do you find the best timing for each rpm/load cell in the timing map. Are you raising the scales for the load columns past the stock values?
Old Sep 30, 2004 | 04:37 PM
Matt Vassallo's Avatar
lifelong learner
depends on the maf used...
theres a couple of ays to do it, im sure some wont share info as readily as others
rest in peace tim.
Old Sep 30, 2004 | 05:04 PM
StinkyZ's Avatar
I'm not worried about the maf. Lets just say your maf can read as much air as your car can pull through it. Do you guys set the load scales to the highest load possible, just below it, leave it stock? Timing is what I'm more concerned about. Are you guys just raising it until you hear it detonating and back it off? I'm sure some people wont want to share but thats cool.
Old Sep 30, 2004 | 06:32 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
It's all a compromise. There's a certain ideal range for timing advance and the benefits of more timing drop off rapidly at a certain point until you're actually losing ground. Also, pulling back timing and running a conservative afr of 11:1 can let you run more boost and make more power on pump gas than more timing with less boost. Some of the higher hp pump gas dsm folks like Dre with the custom-targa 2g run very low timing (keep a sharp eye on the egt timing levels) with sky high boost- and Dre has spent enough time on the dyno to prove that he could make more power doing it that way.
Here are two threads on timing that may help.
http://www.fullthrottletech.com/foru...hread.php?t=99
http://www.fullthrottletech.com/foru...5&page=1&pp=10
I don't know how you're detecting knock but I wouldn't recommend waiting until you can hear it with your unaided ears. If your ecu can't process it in any way, set up an earphone/amp off of the knock sensor line and listen for it manually. http://home.netcom.com/~bsundahl/kno...nockSounds.htm
