RUCA upgrade Q
Old Sep 16, 2004 | 09:24 PM
agentAndy's Avatar
more class than college
Default RUCA upgrade Q
when getting aftermarket ruca's on a s14 do you need to replace the traction and toe rods as well?
I mean will the alignment be ok with only the ruca's being added(and adjusted to correct the bad camber)?
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Sep 18, 2004 | 08:03 AM
MaxType 240's Avatar
All Around Maxed
Default Re: RUCA upgrade Q
No need to replace traction and toe components. You're alignment w/ RUCAs will fall within spec. I've been running like that for 2yrs.
Jesse
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old Sep 18, 2004 | 08:09 PM
agentAndy's Avatar
what do you mean by " starts to add up"?^^^^^
Old Sep 18, 2004 | 08:19 PM
Chin's Avatar
MASTER BREWER:HOT TEA
Ride harsness, with no more bushings will make the car ride like it was a go kart...and pretty much handle like one...
Old Sep 18, 2004 | 08:20 PM
Matt Vassallo's Avatar
lifelong learner
Originally posted by John
that completely depends on how low you lower the car. Your car is not that low Jesse, but mine for example, is on the ground now, so I needed more camber correction, and as such, more toe.
exactly
the more baller you are
the more stuff you're scraping on
the more the ruca pushes the spindle outwards giving you toe out..
rest in peace tim.
Old Sep 20, 2004 | 02:38 AM
All Around Maxed
Good point, at least there is more selection (cheaper) these days. I can't lower mine b/c the tires are hitting the fender...
Jesse
Old Sep 20, 2004 | 03:08 AM
lifelong learner
see thats where more camber / fender rolling / hipari comes into play.
rest in peace tim.
