Wooohooo!!! Car Is Finally Fixed!!!
Old Aug 24, 2004 | 07:18 PM
spoonfed's Avatar
Tha numba one stunna
Default Wooohooo!!! Car Is Finally Fixed!!!
Well after replacing:
(this is all in the past month :o)
Cat-back exhaust
MAF sensor
plugs (ngk vpower)
wires
cap
airfilter
oil flush and change
fuel filter
ps/fan belt
lucas fuel system cleaner
running 93 octane
removing air pump
removing vacuum canister
blocking EGR valve
fuel lines swaped for hoses (instead of hard lines above manifold)
brake booster hose
alternator
alternator belt
alternator/starter cable
p/s stop leak and hose repair
cleaned throttle body
PCV valve (what a pain)
blocked bypass hose on intake tube
blocked off all vacume lines on throttle body
degreased engine/bay/harness
cleaned plugs to sensors
And probably a shitload of other things Im to tired to remember right now....BUT....Now its finally driving great!! even when its cold. It feels like I just really got it since it has'nt been right since I bought it.
still to come this weekend:
coolant temp sensor (to ecu)
temp sensor (to gauge)
o2 sensor
exhaust gaskets
gut the cat
and a seafoam treatment!!
... content in sig not work friendly
Old Aug 24, 2004 | 07:20 PM
Josh's Avatar
Dr. Doom
you need a honda
Old Aug 24, 2004 | 08:05 PM
dan's Avatar
dan
Get the fuck off my lawn
instead of gutting the cat, try to find a hollow secondary "cat" from an S14. also known as the "dummy" cat. it will save you time. or just buy a test pipe.
glad to see you got everything in order, thats about the best list i've seen as far as what should be checked/replaced when getting a 240.
Old Aug 24, 2004 | 08:53 PM
Jonas's Avatar
good to hear man, lemme know and we can make you a test pipe and see if yuo are still interested in that short ram... congrats!@
Jonas
Old Aug 25, 2004 | 06:03 AM
spoonfed's Avatar
Originally posted by Mars_302
So what was the acutal problem?
dunno...I did the alternator, fuel hoses, brake booster hose, PCV valve, EGR block off and degreased engine plus carb cleanered the throttle body all yesterday and when I finally started it back up it was idleing at like 2k so I droped it down as low as it will go and it ran perfect after that!
Old Aug 25, 2004 | 06:04 AM
spoonfed's Avatar
I prolly will...
Old Aug 25, 2004 | 08:20 AM
Matt Vassallo's Avatar
lifelong learner
Default Re: Wooohooo!!! Car Is Finally Fixed!!!
Cat-back exhaust
MAF sensor
plugs (ngk vpower)
wires
cap
airfilter
fuel filter
ps/fan belt
running 93 octane
removing air pump
blocking EGR valve
brake booster hose
alternator
alternator belt
o2 sensor
exhaust gaskets
gut the cat
02 sensors are weak. you dont need one.
exhaust gasket, go for the mr gasket exhaust manifold gasket for the KA. it's copper, re useable a million times, and 9.99
rest in peace tim.
