Anyone installed a mechanical WATER TEMP gauge?
Old Aug 17, 2004 | 03:12 AM
spoonfed's Avatar
Tha numba one stunna
Default Anyone installed a mechanical WATER TEMP gauge?
I purchased a mechanical water temp gauge since my stock one has been mia since I bought the car...however there is no place on the water inlet that I can see to put the sending unit anyone know of a block plug or anything that can be removed to house this? Anyone installed one before?
... content in sig not work friendly
Old Aug 17, 2004 | 06:33 AM
Matt Vassallo's Avatar
lifelong learner
1) Drill and tap a hole.
2) get the correct adaptor from amazon hose
3) think of some other solution i didnt think of
rest in peace tim.
Old Aug 17, 2004 | 07:07 AM
Jap's Avatar
Jap
VTEC Out
Get one fo those nifty colorful splice into your water pipe adapters .
Hondata saves lives
Old Aug 17, 2004 | 09:59 AM
Jeff240sx's Avatar
Cpt. Negative
GReddy radiators have an orifice for an aftermarket gauge probe. Theirs fits a greedy gauge, but you can get a conversion fitting. That's the ballers way to do it. Buy a $500 part to install a $50 part.
-Jeff
** This space reserved for someone else's witty quote **
Old Aug 17, 2004 | 02:10 PM
spoonfed's Avatar
Originally posted by John
ghetto way - small section of pipe, splice into lower water hose, insert temp probe in there.
any paticular way you sugjest? I was thinking maybe a t fitting off one of the heater hoses or some other 5/8 hose....
Old Aug 17, 2004 | 02:11 PM
spoonfed's Avatar
also would it matter where I tap it...another words is the tempature the same in the top hose as the bottom?
Old Aug 17, 2004 | 02:25 PM
lifelong learner
if its the same temp in the top hose as the bottom hose, then screw a radiator, just bypass it entirely!
rest in peace tim.
Old Aug 17, 2004 | 05:02 PM
spoonfed's Avatar
omfg Im dumb...
Old Aug 17, 2004 | 10:35 PM
Chin's Avatar
MASTER BREWER:HOT TEA
atleast he picked up why a radiator is there. What you are looking for when watching a water temp gauge is just consistancy. If it is at 180F every day and one day it shoots to 220 then you know you got a problem.
