Stock turbo swap
Old Aug 11, 2004 | 01:02 PM
HAVIK's Avatar
Is That Turbo? Psssst!
Default Stock turbo swap
I am going to change out my turbo for another stock turbo. I was wondering how har it is to swap out the turbo? How much work is envolved?
Old Aug 11, 2004 | 06:19 PM
RubberBerner's Avatar
Sideways Maffia
unhook all connections on it. remove turbo. place in new turbo. reconnect all things you previously disconnected.
NOBAMA!
Old Aug 11, 2004 | 11:16 PM
dan's Avatar
dan
Get the fuck off my lawn
hahaha if only it was that easy.
-move power steering reservoir out of the way
-disconnect downpipe from o2 housing
-disconnect hotpipe and intake connections
-disconnect oil and coolant lines
-remove turbo/manifold/wg/o2housing assembly
-remove turbo from manifold and o2 housing
-reverse install.
it sucks.
Old Aug 12, 2004 | 12:01 AM
Jonas's Avatar
takes about 5-6 hours... had mine done a bit sooner though... while you are at it make sure all the nuts n bolts are locked up tite and replace the gaskets while you are at it...
Jonas
Old Aug 16, 2004 | 12:17 PM
lillzilla's Avatar
Fallen from grace~
just had it done at X A T sat.... it's alot of work but not to hard .
if you got to ask let them do it ...
good work isn't cheap
and cheap work isn't good .....
Old Aug 16, 2004 | 07:03 PM
cyanide's Avatar
have fun with those hard lines (coolant and oil)
Old Aug 17, 2004 | 08:38 AM
Chin's Avatar
MASTER BREWER:HOT TEA
some times expensive work isnt good work.
Old Aug 17, 2004 | 07:25 PM
JonNoH's Avatar
doesnt even lift
true
Pollo is the best admin there ever was ever
Old Aug 19, 2004 | 09:43 AM
Jonas's Avatar
sometimes my friend sean works at xat , he is a close friend of mine, sometimes he helps me on car stuff... sometimes he works at xat... sometimes as long as u have basic knowledge of location of the lines, how to get the manifold off etc you shhould be able to do the turbo swap on your own...
Jonas
Old Aug 19, 2004 | 03:58 PM
Chin's Avatar
sometimes they dont have sean work on cars..lol
