brake lights stuck on...
Old Jul 4, 2004 | 03:40 PM
jeffronismo's Avatar
Don't be a quitter...
Default brake lights stuck on...
My brake lights are stuck on and I cant see that good under the dash to tell what the problem is. I have disconnected my brake lights in order to save my battery. What is most likely my problem? HOw easy a fix is this? Thanks
Originally Posted by satanshatch
"If it's got tits or wheels you're always going to have problems with it" - My father
Old Jul 4, 2004 | 04:49 PM
JagnMe's Avatar
Slowey
happened to me last week but my light housings melted cause if it resulting in $150+ in parts.
there is a rubber/ plastic grommet thats supposed to be on the brake pedal. it pushes in a switch that in turn, turns the brake lights off. this grommet either fell out or most likely broke. theyre like $4 from the dealership.
.buck19.
Project Green Hawtness in progress.
Old Jul 4, 2004 | 04:50 PM
Epstein's Avatar
Retired
brake light switch on the brake pedal is stuck. Common problem. Replace it.
Old Jul 4, 2004 | 05:23 PM
.buck19.
Yeah thats what it turned out to be. The rubber pieces were all over my floormat. Now i just need something to help me temporarily until i can get the real part from nissan. Thanks
Old Jul 4, 2004 | 10:49 PM
inikoni's Avatar
Yonaka Hashiri-ma
yeah i think i am having the same problem with my 240....i have to flash the hazards when i am stopping cause i have no brake lights...lol
UniversityCentralFlorida
Old Jul 6, 2004 | 10:54 AM
buck19's Avatar
Forever Broke Nissan
us a nut a bolt. should work. few friends have done it on other vehicles. and i think it would be more permanent since its a bolt.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jul 6, 2004 | 10:57 AM
buck19's Avatar
also it should be the same as the 240. if the parts are the same then call up doug casson at autoway chevrolet, order it, and pick it up at will call cause they have them in stock. they sell at least 10 a day. i used to work there.
the number there is 727-536-7871 ext 327. they are between ulmerton and gulf-to-bay blvd on us 19 on the east side of 19.
Old Jul 6, 2004 | 11:20 AM
SILVIA-S14's Avatar
Suck A Turd!
Just out of curiousity. I know there is a switch that the clutch pedal pushes down to get the car started. Starter interlock switch i believe? .....i am assuming this switch you guys are talking about is under the brake pedal? and hence different altogether. I gotta go check under there. I wasn't aware of it if that's the case......
Oh yah, i already replaced my clutch one on the s13 a while back. S14 is doing ok.
RiNKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Jul 6, 2004 | 11:48 AM
buck19's Avatar
ah dont replace the clutch one. just connect the wires. dont have to clutch start then.
Old Jul 6, 2004 | 11:51 AM
buck19's Avatar
and yes its the same setup as the clutch pedal. not sure if the switches are the same cause i dont have the clutch one. did auto-5spd swap.
