FPR questions
Old Jun 19, 2004 | 06:39 PM
Ralph's Avatar
TR Balla Donor Supreme
Question FPR questions
First question is, does anyone know id the KA FPR is interchangeable with the SR one? I've read alot of mixed opinions on it, mainly people stating that if you order a Nismo unit, which is a direct replacement for the stock fuel rail, that it will bolt onto a KA motor. My question is in regards to OEM.
Second question is i've been googling for hours on end and finally came up with a post on another board that a member asked. He wanted to know what were the symptons of a FPR going bad were and one of the Moderators said to test the FPR by disconnecting it at idle. If the rpms slightly increased, then it is working. Does anyone know if this is true?
TR Profile
Myspace Profile
Old Jun 19, 2004 | 08:23 PM
buck19's Avatar
Forever Broke Nissan
i know that whenever i pull the vac line off the fpr the idle drops a little and get irratic.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jun 20, 2004 | 04:13 AM
Ralph's Avatar
See, when I pulled mine off...it might of got irriatic for a second...then its normal
TR Profile
Myspace Profile
Old Jun 20, 2004 | 12:46 PM
Matt Vassallo's Avatar
lifelong learner
so you tested your fuel presure ?
rest in peace tim.
Old Jun 20, 2004 | 04:56 PM
Ralph's Avatar
Yeah I pulled 38psi idle, 48 vacumn line unhooked. I am starting to think more and more that its my recirc valve leaking under heavy load causing me to run extremely rich at high rpms.
TR Profile
Myspace Profile
