Possible serious damage????..PLEASE READ (long)
Old Jun 10, 2004 | 07:04 AM
StealthmodeS14's Avatar
Default Possible serious damage????..PLEASE READ (long)
About a month ago I had a real problem with running rich....and as we all know there are so many factors as to why it would run rich...I decided to knock them all out one by one. Got the car all back together and tried to start her up and it wouldn't start...ended up being a massive fuel leak started due to stressed o-rings. I went and replaced both o-rings on each injector and she fired right up.
Drove well for two whole days....this past weekend I started it up after paying my cell phone bill and I noticed the idle was lumpy, but nothing real bad. I thought nothing of it and proceeded to drive to my buddies house. Well I got about two miles down the road and was at a stoplight when all of the sudden my idle really starts to dip (I had it set at 1,000....it dipped to 800, 500, 300) and I looked in the rear view and noticed TONS of thick white smoke pouring from the exhaust. I kept it alive and drove it into a parking lot and it just died.
I got around to it the day after to see what was going on. I pulled all the spark plugs and noticed they were semi black, but number two was pitch black. On a whim I puled the fuel rail again and sure enough the lower o-ring was bulged and leaking like a siv. After a couple of tries I finally got it to seat right, pressurized the systme and noticed no leaks. Installed the rail again and tried to start again....nothing....number two was filled with fuel again. Either the o-ring bulged again (didn't have time to check) or I'm thinking the injector is stuck open (have yet to check the resistance).
Cliff Notes:
. Replaced injector o-rings
. two days later idle is bad and TONS of white smoke purs out of the exhaust
. fixed o-ring on number two that was found to have bulged
. cyllinder still fills with gas at a moments notice when pressurizing fuel system
Questions:
1. My injectors DO NOT have the small pintle caps on them (the yellowish/tan four pronged plastic hats that are found on the "squirting" end of the injector). Are these caps neccessary for proper operation....I have had friends tell me that they will still spray fine with them off......but I think they are there to help protect the lower o-ring from doing exactly what mine did....bulge...any thoughts?
2. In regards to the white smoke....what could that have been. I know black smoke is fuel and white is coolant. I presumed it to possibly be a head gasket, but the car ran for a good 5 minutes after it first started smoking and my temp stayed at a solid 180 degrees and after checking, there was no coolant in oil or the reverse......what could that have beem?
Thanks guys....give me anything and everything you might be thinking...
And I assume most here go to FA as well, but I thought I would post it here in case they were some that don't..
-Bill
Holla back youngin'...
Old Jun 10, 2004 | 09:11 AM
MaxType 240's Avatar
All Around Maxed
When my #2 & #4 inj were leaking, a ton of white smoke was coming out from the exhaust.
New set of o-rings solved that (plus learning how to properly install injectors).
I have 8 270cc injectors laying around, let me know if you need some.
Jesse
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old Jun 10, 2004 | 10:11 AM
You have a PM Jesse....
-Bill
Old Jun 10, 2004 | 01:37 PM
Shadytrixta1's Avatar
has whippled VTEC
hey bill i hope you figure it out, without any permanent damage. my car still isnt running right by the way jesse what are you looking to get for four of those injectors, and could you tell me the proper way to install the fuel rail/injectors. because ive had trouble with this before.
Old Jun 10, 2004 | 04:48 PM
tampamax's Avatar
Jesse
Are Ka injectors 270? For some reason i thought they were 240. I wonder where i could have gotten that idea?
Old Jun 12, 2004 | 08:58 PM
Hey Cody...as far as I know the best and easiest way to correctly install the injectors is to make sure o-rngs are in good shape of course. Lube them up with some type of oil/grease...motor oil worked fine for me last time and use they should just pop right in...simple as that.
Then again one of mine sprang a leak so...hahahaha
-Bill
Old Jun 14, 2004 | 02:44 AM
All Around Maxed
Cody, no need to remove fuel rail (although easy). I have 8 more injectors sitting around. They were free for Bill b/c we go way back so I don't have a price.
I still say check your compression first. It's easy and cheap. Car still not idling right? Replace that BOMEX on crack and it'lll clear up
Jesse
Old Jun 14, 2004 | 08:01 AM
has whippled VTEC
Haha thats funny, but really ive been looking but no one has a stock bumper for me.I can just get a compression checker from autozone cant i?Or should i just take it somewhere?
Old Jun 14, 2004 | 08:14 AM
Yep...AutoZone, Sears, ect...will all have them. You don't really need to have someone do it...it's pretty easy to do.
-Bill
