Help!!!! detonation problem
Old May 5, 2004 | 06:13 AM
RHD180sx's Avatar
Default Help!!!! detonation problem
I have a 93 240sx that has bad detonation problem. I put in better gas and most of it is gone, but I can still hear a little every now and then. I built several 240's but never had this problem. any idea's ?
Old May 5, 2004 | 06:15 AM
RHD180sx's Avatar
Sorry, the car is a stock 240sx...
Old May 5, 2004 | 06:21 AM
MaxType 240's Avatar
All Around Maxed
Ignition:
Spark plugs - too cold?
Timing
Cap, Rotor, Wires
Fuel:
Filter: dirty?
Fuel Sock: dirty?
Fuel Pump: dying?
It's always the little things that get me...
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old May 5, 2004 | 05:07 PM
Matt Vassallo's Avatar
lifelong learner
Originally posted by MaxType 240
Ignition:
Timing
Cap, Rotor, Wires
Fuel:
Filter: dirty?
Fuel Sock: dirty?
Fuel Pump: dying?
too cold of a plug won't cause pre ignition or detonation, it will simply foul out when the car is cruising, because there won't be enough combustion heat to keep the plug at self cleaning temperature.
timing and carbon build up will probably both do it on a ka
rest in peace tim.
Old May 6, 2004 | 08:33 AM
buck19's Avatar
Forever Broke Nissan
BG fuel system clean. on of the better tune ups you can buy for the money.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old May 6, 2004 | 10:28 AM
RHD180sx's Avatar
I'm willing to try anything @ this point, so far I've tried plugs, rotor, cap, fuel filter, timing... I'm starting to think it might be carbon build up...thanks guys
Old May 6, 2004 | 11:09 AM
All Around Maxed
oh boy, I did write that... thanks for covering me.
Anyways, clean the engine to eliminate hot spots (don't really think it'd be that bad but it's an idea).
Go over the fuel items and IACV suggestions first.
