I NEED HELP QUICK!(timing chain)
Old Feb 14, 2004 | 03:56 PM
car ram rod's Avatar
SlowerThanYou
Default I NEED HELP QUICK!(timing chain)
How do i take this off without fucking anything up. I have to replace my head gasket. The chain isnt messed up so i want to be able to put it back on. i dont want to break anything. please help.
Old Feb 14, 2004 | 04:32 PM
buck19's Avatar
Forever Broke Nissan
you shouldnt break anything. its a timing chain. to make things easy on your self mark evertyhing.
mark your crank pulley to the block
mark your cam sprockets to the upper timing chain
mark you lower timing chain to the middle timing gear.
when you take things apart try and keep you lower chain tight. also there are 2 brackets under your intake manifold that need to be unbolted if you dont want to replace the intake gasket. drain your radiator to so you dont get it every where
where do you live
car 55. do you need my assistance?
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Feb 14, 2004 | 04:50 PM
RubberBerner's Avatar
Sideways Maffia
before you take the cam gear off, and everthing is @ TDC...put a block of wood with a string on it to "shim" the chain (below the head), therefore you won't mess up timing on the lower end.
NOBAMA!
Old Feb 14, 2004 | 04:55 PM
buck19's Avatar
exactly. forgot that part
