possible tranny problem...
Old Aug 4, 2003 | 07:13 AM
Jonas's Avatar
Default possible tranny problem...
When iam sitting at idle there is this noise coming from the tranny, but when i step on the clutch it goes away??? and when iam downshifting into second gear it grinds???? untill i put it in neutral and then back in second, it does this everytime...and when i put it in 4th gear it comes out of gear by itself and into neutral unless iam actually holding the stick and keeping it from coming out of gear... what is my problem here??
Jonas
Old Aug 4, 2003 | 07:21 AM
SILVIA-S14's Avatar
Suck A Turd!
shift forks?
low on fluid?
really burned up oil?
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Aug 4, 2003 | 01:18 PM
Enthalpy's Avatar
TR Balla Donor Supreme
sounds like a drifteR pwned your tranny before you did....
Old Aug 4, 2003 | 01:33 PM
95CivicCoupe's Avatar
The noise might just be from the throw-out bearing. You may have a faulty throw-out bearing. If you installed a new throw-out bearing, there can be one of two things, the throw-out bearing may still be faulty, or the throw-out bearing is not pressed on properly.
Other then that, all the other problems all suggests that you should start looking for a KA tranny and replace it with the one that you have.
Old Aug 4, 2003 | 01:34 PM
JapDanny's Avatar
Anti-Flag
I'm with Scott .
Drifter 0wnz tranny ! Did it have an aftermarket clutch in before you replaced it with the Spec ?
Fuck the Flag and Fuck you
If your going to post , please fucking think before you start talking out of your ass !
Old Aug 4, 2003 | 02:44 PM
SAFKO's Avatar
Light Bulb With Horns
i just did my friends swap and his car had a completely destroyed clutch. it was a nice aftermarket one too. we had to change that. so your car was prob a drift car as well. could be the throw out bearing.
wut?
Old Aug 4, 2003 | 02:58 PM
Default Re: possible tranny problem...
This most like is what I had said in the previous post, either a bad throwout bearing, or the throwout bearing was not pressed on properly, or an output shaft.
Clutch might be going (not a big probablility), must likely the 2nd gear synchro is wearing or worn. If you want to attempt trying to fix this, try changing fluids, at times, it helps.
This, just means....get the tranny rebuilt, or get a KA tranny and replace the bellhousing.....
Old Aug 4, 2003 | 07:10 PM
Jonas's Avatar
okay i think i have narrowed down my options and iam going to go and put in my KA tranny, it will make life alot easier and will destroy other problems because i know for a fact that nothing is wrong with my KA tranny... as for the throw out bearing i will double check that also when we swap the ka tranny in there...thanks guys for the help...
Jonas
Old Aug 5, 2003 | 01:35 PM
Bobbysr20's Avatar
Get to the chopper!
more than likely your low on gear oil
81 CJ5
90 jetta 8v (my ex)
