Evo ecu in a 2g 6 bolt swap
Old Jan 20, 2011 | 05:26 PM
Romeyo07's Avatar
Default Evo ecu in a 2g 6 bolt swap
I was told I can use an evo ecu on my 2g 6 bolt swap. Anyone familiar with this?
Old Jan 20, 2011 | 05:42 PM
x8psycho8x's Avatar
Talk to OMGosh & Wishiwasfast. their both running evo ecu's
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Jan 20, 2011 | 06:48 PM
omgosh's Avatar
Yep. Just switch some pins around at the ECU plug. Ask away.
Old Jan 20, 2011 | 06:59 PM
Boost Demon's Avatar
I used a 2g ECU/DSM Link Ver 2.5 to tune my Evo VIII before ECU Flash was really doing anything impressive . I got a patch harness for $99 @ RRE to avoid hacking up all but one wire on the car .
Old Jan 20, 2011 | 07:55 PM
omgosh's Avatar
Sorry but I do not see the point of a patch harness. You just swap like 6 pins, pull one, and add one. Takes like 10 minutes. Unless Evo->2g is different..
Old Jan 21, 2011 | 03:39 AM
The point is it's another way to plug-n-play without having to worry about how to un-do what was done. Just offering another route is all.
Old Jan 21, 2011 | 11:22 AM
omgosh's Avatar
I guess ease of use is a good point...I didnt mean that as an attack on patch harness users I just would rather re-pin. Its not like Im ever going back to a DSM ecu lol.
Old Jan 23, 2011 | 06:38 PM
wishiwasfast's Avatar
I pin'ed mine in 5 min. It's easy to get the evo ecu running, I just can't tune it for the life of me.
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Jan 23, 2011 | 07:17 PM
x8psycho8x's Avatar
don't feel bad. Dave's explained MS to me countles times and I still can't tune haha
95 eclipse rs - dd
Old Aug 13, 2011 | 01:48 AM
live4redline's Avatar
Question bump...
As of this source link...
evo 8 ecu swap in a 2g - CarolinaDSM Forums
What all Cam Angle Sensors are gonna work with the evo ecu? This guy did it with the Spider 4G64, and you guys are using?
I only ask because I know the 1g and 2g eclipses differ and the spyder is slightly odd on some stuff and it makes me wander. In my case with a 4G64 block and I'm in the market for a 4g63 dohc head id like to know what I need. More or less I would like someone to confirm for me that this evo ecu swap will work for a 2g 4g63t and ill base my build on that. And if so, its safe to assume people running 1g cam sensors cant run the evo 8 ecu right???
(Current project is a 4g64 1995 mighty max, soon to get a Sirius1 4g64/4g63t hybrid motor + turbo swap and god willing tuned on a evo 8 ecu.)
