looking for a quick spooling turbo.
i have found this turbo from precision.
i want to flow a lot of air but i want a quick spool, so should i go with the 43 A/R or 63 A/R housing?
PTE SCM60 Series (Mitsu Bolt-On / 580 HP) - Modern Automotive Performance
AWD FTW!
AWD FTW!
that turbo is a laggy pig with both housings. far better turbo choices out there.
start with your HP goals or better yet how much money you have to make your car fast and what parts you currently have and i can give you some good advice on what to use.
my favorite quote
my favorite quote
my goal is right at 420whp. i have laggy super 20g turbo, big fmic, 560cc injectors, fuel pump 255lph, intake, 3in exhaust, safc, boost controller. i just want to boost faster and make it sppollike the stock turbo did. i also have a head being built for it aswel but its not on the car yet.
AWD FTW!
AWD FTW!
Um. Which 20g is that? td05 or td06? Either way, you have plenty of turbo for that power level. No reason to upgrade. Are you sure you dont have any exhaust/boost leaks and all your gaskets are good?
How much boost do you run right now? And when does it spool? I have a td06 20g and it hits 15psi by 3100rshared_pm. Yeah I have a 2.4...but still you should be getting full boost by like 3600-3800...that is not a laggy turbo.
Most likely best turbo for your needs is FP 68 HTA.
my favorite quote
my favorite quote
